Results 1 to 8 of 8
This is a discussion on Dash Temp Display backlight out---easy fix? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Sooo in my 06 WRX wagon the little green backlight that lights up my temperature display on my dash went ...
    Registered User pepper06's Avatar
    Nov 2009
    Stuttgart, Germany
    Sooo in my 06 WRX wagon the little green backlight that lights up my temperature display on my dash went out.
    Easy fix?
    Wow, this car rocks.
    I live on the autobahns of Germany
    Ravens for life.
    Aug 2008
    Kennett Square, Pennsylvania
    I'm assuming your talking about the coolant temp gauge backlight? If so..There are bulbs back there..popping the cluster out isn't that difficult, once its out the bulbs can be accessed...
    Nov 2009
    Stuttgart, Germany
    nooo im actually talking about the outside temperature display--the digital one right below the coolant temp gauge and the gas gauge. But does the same idea with the bulbs behind the cluster apply? The display works, there's just no light, and it's bugging me when I drive at night---I have my green glow on the right showing my odo and mileage, but no green glow on the left.
    Ravens for life.
    Aug 2008
    Quote Originally Posted by pepper06 View Post
    You will prob still have to pull the cluster to replace the bulb in that..there is a possibility it is a smaller bulb like the ones in the clocks or the cruise control switches on the foresters/legacies etc etc..have you tried tapping on it a tad to see if you can jar it enough to work? I'm going by the most common prob with these, and its usually a burnt out bulb however i suppose you could have a loose/damaged wire somewhere...
    Registered User Sarra's Avatar
    Aug 2008
    Dreadford, OR
    Wow, sounds like Subaru still hasn't switched from '$3 parts bin special' quality to 'OEM' quality parts. I mean, seriously, the OEM clock in my 02 has FIRE damage on it. o.O It still worked intermittently too.
    Getting a 52mm clock 'gauge' to go in the pod that replaced my OEM clock.
    Good luck replacing that bulb.
    Oh, on this subject, is it even possible to replace the bulbs that light up the Cruise and Fog Light switches? Not the "on/Off" indicator lights, but the backlight in the switch itself? I have to poke blindly in the dark at night to turn my Fogs/CC on now.
    Aug 2008
    Quote Originally Posted by Sarra View Post
    Yes you can quite easily replace the green backlight bulbs in the cruise/fog light etc...switches...there is usually 2 small bulbs back there in each switch housing..you can usually pick them up at radio shack or the dealer usually has them in stock, there not that expensive...you drop the cover under the steering column, unplug the switches, and the unclip them from the cover and they should pop right out...
    Aug 2008
    Dreadford, OR
    Gotcha. I had that lower kick panel off to cut my green test connectors off and white write plug off and wire in some switches, and had removed the switches, but didn't want to disassemble them if they were not going to be easy to reassemble.
    I'll go ahead and pull them once I get on break and find the bulbs I need, thanks.
    Aug 2008
    no prob man..the bulbs usually pop right in the side.. and can easily come out with a pocket screwdriver...
