Results 1 to 8 of 8
This is a discussion on Intake problem? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; alright so i got this new intake..installed it and plugged the connector into my MAF sensor. turned my car on ...
    Registered User SKRIPTED's Avatar
    Nov 2009
    Springfield OH
    Intake problem?
    alright so i got this new intake..installed it and plugged the connector into my MAF sensor. turned my car on and it started then shut off after a couple seconds. I unhooked the connector and my car runs fine. Curious as to why my car wont run with the wire being connected. any help?
    Dec 2003
    Dallas, TX / Sterling, VA
    Did you install the MAF backwards?
    Nov 2009
    Springfield OH
    they only way i could install it would be if the intake would of been face backwards. Does this mean i should look at getting a new one?
    Quote Originally Posted by SKRIPTED View Post
    A new what? Intake? Or MAF? What intake did you buy?
    Jan 2005
    Eh, whaaaaa?
    Did you try resetting your ECU after you connect the wires? Don't know if it's going to do you any good, but it's worth a shot.
    Seems odd to me that it's running without it connected and not running with it connected. If I remember correctly my 02 wouldn't even start when the MAF was disconnected.
    Cody
    Nov 2009
    Springfield OH
    it was from mqtautoparts. but yeah its really odd as to why it wont run when its connected. It runs fine when its not connected but idk if that will have any long term effect so i want to get it fixed. my buddy said i need an aftermaket MAF sensor but idt i need that.
    Registered User mexicanzero's Avatar
    Oct 2009
    Ottawa Ontario Canada
    well it is backwards... at least my 03 wrx (which is on stock intake) has it the other way, what year's yours?
    but i dont think the orientation matters that much...
    maybe unscrew it flip it around and see how the car runs then
    if not then put the stock intake back on and see if that helps it...
    btw other than maf do you have any codes?
    -Alex
    Moderator Donkey's Avatar
    Da boonies
    Only pointed the solution out to you a week ago..................
    want some upgrade options ??
    2002 FORESTER S
    1998 FORESTER S
