Need help with p2096 code
Results 1 to 6 of 6
This is a discussion on Need help with p2096 code within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm not sure if this is the right place to post cel questions. I have an 09 wrx with tsudo ...
    Registered User supranai's Avatar
    Oct 2009
    Michigan
    I'm not sure if this is the right place to post cel questions. I have an 09 wrx with tsudo cat-delete downpipe mated to a perrin cbe. I'm also running cobb access port 91/92 octane stage 2 map. The downpipe came with a cel-fix. The stock o2 sensor is in place, but every couple of days the check engine, traction control and cruise control lights come on. Check engine and traction control lights stay on but cruise control light blinks. I would reset the ecu and the same problem would show up again in about two days of driving. The code reads: post catalyst fuel trim system too lean bank 1.
    Oct 2009
    I just bought a certified 08 with 12k and the dealer gave me the catless downpipe the previous owner had installed (but they removed for inspection). So, I now have the stock catted pipe on. I recently got the exact same problem you did. CEL and Traction Control off lights are on, and the cruise light blinks. I can't manually turn on traction control or cruise. Any luck solving your problem yet? My car is going in tomorrow morning to have the dealer check it out, so I'll post what they say.
    Registered User 97_04's Avatar
    Feb 2006
    I'm not a pro, especially on the 09's but have you checked the plugs/coils/o2 sensor? I know you said it came with a fix even though the o2 sensor is in place. Being so new and the fact that you have an AP should keep it from tripping any codes but you should check the obvious/physicals before going in deeper.
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by DammitMike View Post
    When the CEL illuminates the ECU disables the traction control and the cruise control hense those two lights coming on...
    Oct 2009
    Yeah I found that out this morning at the dealer. Sorry, I'm completely new to Subarus. Mine threw a p0420 for a problem with a reading from the cat.
    Oct 2009
    Michigan
    I was told by some locals that my car just needed to be tuned to run catless...planning on doing just that sometime this winter. Hope tunining it will get the bug out.
    09 Satin White WRX
    89 Pearl White Supra Turbo
    Stink-Eye-Mob #609
