ALOT of shaking at idle
Results 1 to 15 of 15
This is a discussion on ALOT of shaking at idle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; just started today my cel has been on since i put my catless downpipe on. today it started shaking alot ...
    Nov 2009
    Red face ALOT of shaking at idle
    just started today my cel has been on since i put my catless downpipe on. today it started shaking alot and it seems to be pushing alot of boost at low rpm and now my cel is flashing. the engine is moving quite a bit too. and the exhaust sounds like its sputtering. no boost gauge in the car.. but my blow off valve has never been that loud at low rpm.. any ideas????
    03 wrx
    list of mods:
    Injen SES catback exhaust
    Injen coldair intake
    HKS catless downpipe
    HKS ssqv III blowoff valve
    Grimmspeed crossover pipe
    Nov 2009
    and when at a stop my rpms drop real low like its gonna stall but doesnt...
    Registered User littlerussian's Avatar
    Dec 2008
    twin cities, MN
    if ur check engine is flashing, it means ur cylinders are misfiring. That means its either a fuel problem or an air problem. my car used to shake at idle too, and the check engine started to come up and flash, the car kinda revved up and down a little on its own too without me pushing on the gas. My problem was a ripped intake manifold gasket. Most likely ur problem too. Or it could be a fuel injection problem. But check ur intake manifold gaskets. there's 4 total, 2 on the right side, one sitting right under the manifold, and another one, the most likely one to be causing this problem, is a bit lower, sitting on top of the cylinders, and 2 more just like that on the left side.
    06 WRX TR: stage 2 cobb, HKS TBE, K&N air filter in stock box
    Jul 2004
    Seattle, WA
    Wow, where to start.
    Your car needs to be tuned to run a catless downpipe, so it's running lean.
    Your car needs to be tuned to run the Injen cold air intake because the MAF sensor housing isn't designed correctly, causing it to run lean.
    Subaru's are setup so the extra air is recycled back though the intake, and using a BOV (vent to atmosphere) makes it run rich between shifts.
    If the engine is moving as much as you say it is then you may also have a problem with your engine mounts.
    Oct 2005
    Late Devonian
    Don't worry about the DP - it is a bugeye and that is fine.
    Remove the intake and put on a stock one or get tuned.
    Clean the MAF and see if that solves the idle etc.
    Nov 2009
    the intake has been on for a couple months now with no problems..
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by BKassela View Post
    So you've data logged with a wideband sensor then?
    That's what I though.
    And how exactly are you running "a lot of boost at low rpm"?
    Jul 2004
    Seattle, WA
    03 wrx
    list of mods:
    While you where under there, did you also install an uppipe?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I really think it's the blow-off valve. Especially if it feels like it's going to stall while at idle. That's a common symptom for a junk BOV, or one that hasn't been properly adjusted.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Nov 2009
    stock uppipe(for now) and the bov has been on for months too no problems..if its misfiring then those parts shouldnt have anything to do with that. all my mods have been on for atleast 3 months.
    Jul 2004
    Seattle, WA
    Ok. Let me start over.
    Your check engine light is on. Use an ODB-II scanner to find out what the codes are, then post the codes.
    Dec 2008
    twin cities, MN
    like i said, theres probably a small leak somewhere, my car used to drop to very low rpms too at stop just like urs, but didnt stall, then after a few weeks it actually began to stall every once in a while when i stopped or put it in neutral. As soon as that started happening i took it to my mechanic, i had a hole in one of my manifold gaskets. i'll even send you a pic. After he replaced that, no more problems at all, and the cel turned off.
    Nov 2009
    come monday i'll have a odb-II scanner and i'll let you know what i come up with.. from the sound of my intake and bov its getting too much air. i live on a military base and the closest auto store is like 10-15 miles away so i dont chance driving it right now. after christmas its getting pro tuned just need to find a good place. anyone in colorado know a good place on the east side of CO?
    Nov 2009
    P0420 my cat is the only code it came up with could it be my O2 sensor messing everything up?
    Oct 2005
    Late Devonian
    It could be but the symptoms are weird. The rough idle matches at least. In any case, you must get that fixed immediately.
