Results 1 to 6 of 6
This is a discussion on Help Please, Just bought scooby.. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, im lee, just registered as bought my first scooby.. however i have come across a few problems in ...
    Nov 2009
    Hi all, im lee, just registered as bought my first scooby.. however i have come across a few problems in last few weeks.
    Firstly the car is a 01 reg bug eye wrx, 35k,(well thats on the clocks), but does have history and old mots to verfy millage.
    The car is an inport as ive just found out.
    Now to the problems, when i bought it, the engine idled really rough, like fromm 500rpm to 300, then up to 700, it was noticable it only does this every say 10 secs, not constantly., i took it to get a diagnostic and it came back with running lean on bank 1?? wot ever this means? anyway cleared it and its now come back on. The car smells of fuel smells, wen driving, and also when its stood still at lights, it smokes a bit, however it is cold weather season, and if i set off there is more smoke, looks bit bluey, not 100% sure tho on colour. it only does this everynow and then tho, sometimes dont smoke.. the mods to the car, as far as iknow are,
    sti bottom end,
    vf34 ballbearing turbo
    bailey dump valve
    full samco blue hose kit
    CAI induction kit
    Turbo inlet blue pipe
    turbo back exhaust, no cats at all.
    It runs 1.5 bar of boost, but i dont think its been mapped,
    also has a different top mount intercooler, had like 2 extra breather pipes on it from std??? just wot i been told?
    the car runs perfect when u give it some, no misses, no smoke, just all good, just had a idle issue, and smokey on tik over after driving.. Can anyone help me, im not sure weather to seel, as could be trouble, or persavier with it.. any idvice and ideas would be great, anyone experienced any of these probs. the turbo pipe doesnt seem to be a good fit either, hoping to change that this weekend, all pipes have been checked and we cant seem to find a leak, part from turbo pipe?
    one more thing, could the de cats cause this to run lean, and bring light on? the car is a blue wrx, with sti wheels, with private reg h16 ddd, incase anyone knows the car, or seen it when was on ebay recently..
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    just so i'm understanding correctly, when you say "It runs 1.5 bar of boost, but i dont think its been mapped," do you mean it has all of those mods but no tune or engine management?
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    You might want to check to see if the car is even tuned...that's where I would start.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Go to Scoobynet since they will know UK-based garages. The error code you got was probably PO171. It indicates a lean condition and/or a leak in either the pressurized or the atmospheric part of the intake track, or a failure in the vacuum line that runs to the fuel pressure regulator.
    The intake and/or the turbo itself, without a map, could cause the car to run lean and in any case it needs to be sorted anyway, so find some place local to take it and have them look at it.
    Nov 2009
    Quote Originally Posted by wrxtreme06 View Post
    im presuming it has no map, however i was not told it had, and i think the owner would of told me it did, if it did. and yer i was thinking it has all these mods and no setup to management, would be a bad condition for the car to be in anyway. On to my next question? if i removed the exhaust and airfilter, would this change the overall running of the car and clear the lean running of the car..? i just want it back to normal to be fair.. could this lean running be a cause of bad idling? cause it dont idle bad if i drive it steady, and i mean steady.
    Without knowing what map is being run now, if any, it's difficult to determine what might be wrong. Usually a lean condition is seen under load more readily than it is seen at idle, for example, but I'm in another country and what I think won't do the car any good I'm afraid. Take it in and have a garage look at it; find a Subaru specialist in your area.
