Put on your thinking caps plz!
Results 1 to 15 of 17
This is a discussion on Put on your thinking caps plz! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok I am having some problems with my 03 wrx. I had two Subaru shops take a look at it ...
    Registered User Civic_jdm16's Avatar
    Sep 2009
    Clearwater, FL
    Exclamation Put on your thinking caps plz!
    Ok I am having some problems with my 03 wrx. I had two Subaru shops take a look at it and they can't find a problem.
    The Turbo will only boost to 5psi. I think the turbo is junk or maybe the car is in some type of a safe mode.
    Codes \/
    P0031
    H025 Heater Control Circut Low (Bank 1 Sensor 1)
    P0032
    H025 Heater Control Circut High (Bank 1 Sensor 1)
    I have a Front mount intercooler, Header, Downpipe, and intake. On a stage 2 tune. could anybody tell me why Im Haveing thease problems?
    PLZ HELP!
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by Civic_jdm16 View Post
    Codes \/
    P0031
    P0032
    PLZ HELP!
    There's your problem. That setup needs a custom tune. Whether it be a protune somewhere or an open ecu street tune.
    A stage 2 map is designed for:
    Stock IC
    Stock Header
    Stock or warm air intake
    An aftermarket downpipe
    Thats it.
    What will further compound your problem which you did not specify but I am assuming you have.
    1. Any blow off valve other than the stock BPV.
    2. An oil type filter element on your intake.
    Are you running the stock Up pipe?
    Do you have the factory restrictor pill in place?
    BTW pics are worth a lot here.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User mexicanzero's Avatar
    Oct 2009
    Ottawa Ontario Canada
    did any of the shops change your o2 sensor?
    the resistance of the heater circuit should be in the 2-3 ohm range. i dont know the exact spec but if its not much more than 3 ohms i would think it to be ok. in which case theres a damaged wire to the o2.
    to test it unplug the o2 and on the o2 end of the plug put the ohm meter across the 2 heater wires. (sorry not sure which colour they are)
    i change lots of o2's cause of these codes. i've only once in 5 years seen a wiring problem on the cars harness, its always the o2.
    this should solve the codes but it wouldnt cause the car to go into safemode... i dont think...
    -Alex
    Moderator timber's Avatar
    St. George, Ut.
    Another place to look would be your Boost Control Solenoid...this seems to be a fairly common issue with the earlier WRX.
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    Sep 2009
    Clearwater, FL
    Yes I do have a BOV, but its not a good one.
    Its has an intake that runs into the side of the engine bay, I have yet to see it.
    Kinda lost when you say up pipe? there are pipes everywhere!
    I have no clue about this pill or where I would find it.
    Attachment 86277
    I will check the 02.
    Thanks you guys so mucg I will try these things and let you know the out come.
    Jan 2005
    Eh, whaaaaa?
    Your up-pipe is the exhaust piping that runs from the exhaust manifold on the bottom of the engine, up to the turbo.
    Do check your boost solenoid, look into the 3-port BCS's. And GET A TUNE! You're car is not running at all like it should, and you could possibly be damaging the engine.
    Cody
    Sep 2009
    Clearwater, FL
    Ok then I gona guess since its part of the header that its after market, Im starting to get realy upset with the problems im having with this car, I din't build this car. I bought somebody's problem.
    Sep 2009
    Clearwater, FL
    Attachment 86278 Ok Im just guessing here but are these the sensors I need to change? the ones in the Yellow. Should I just go ahead and change them both? and also what can cause these to go bad? Its just kinda wierd how they both went bad at the same time.
    Jan 2005
    Eh, whaaaaa?
    The sensor in question is the one on the bottom of that graphic, the front O2 sensor in the header. You may want to check the wires just to make sure that when the header was installed the person put the wires back in the proper place to avoid melting to the up-pipe. If the wires got melted, that could be your problem and be fixed with a simple wire splice, though I would recommend a replacement anyways.
    Otherwise, your O2 sensor is bad. Replace it and the codes should go away (again if the wires check out okay).
    However, that shouldn't be causing the lack of boost your seeing. Check for exhaust leaks, and wastegate and boost control solenoid function.
    Cody
    Sep 2009
    Clearwater, FL
    Ok this is my current tune. TPG Stage 2 Using 93 octane fuel, stock Injectors, Exhaust, FMIC, Leaking BOV, Header Leak,
    This is what my Cobb Access Port is telling me
    Sep 2009
    Clearwater, FL
    Bump New Idea
    Ok, the shop i am taking the car to for this problem says they can bypass thaese sensors.... does anybody out there know how this is done?
    "SCHIRRA~#16" HOLY *****'N A$$ CRACKERS!!!!!
    Moderator Donkey's Avatar
    Da boonies,Va
    You do not want to bypass the front O2 sensor. Maybe you misheard them or they are idiots. The front O2 sensor is a very important sensor. The ECU needs it for closed loop fueling. Just replace the sensor.
    2002 FORESTER S
    1998 FORESTER S
    Aug 2008
    Kennett Square, Pennsylvania
    +1^....
    I def. wouldn't be bringing my vehicle back to that shop...
    Registered User scubynubie's Avatar
    Jun 2003
    Taunting Happy-Fun Ball
    Also check the vacuum hoses between the compressor outlet and wastegate actuator. The restrictor pill is basically a metal bead. It has a small hole in it and allows the boost control solenoid to work. It should be in the small hose between the compressor and the "T" fitting.
    If you don't feel a bump in that hose, then you will not be able to hit much boost at all. Check that first before you do anything else.
    "I never drive faster than I can see."
    - Jack Burton
    Sep 2009
    Clearwater, FL
    Ok I will make sure to take my car to a new shop....
    and i will try to find the pill.
