Page 1 of 3 123 LastLast
Results 1 to 15 of 34
This is a discussion on bad if the engine oil not sythetic?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i changed the engine oil yesterday and i didn't expect it would affect the car if i didn't get sythentic ...
    Registered User aznbutt3rz's Avatar
    Sep 2009
    i changed the engine oil yesterday and i didn't expect it would affect the car if i didn't get sythentic oil. does it affect the car bad?
    In your owner's manual the specifications for each fluid are listed. Follow those specifications and the maintenance intervals indicated. If the oil you used meets those specs then the source of its base oil or additive package don't matter.
    Registered User Aspen700's Avatar
    Mar 2006
    New Jersey
    what car? did it have synthetic in it before? what did you put in it now?
    '04 Aspen White WRX
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Quote Originally Posted by aznbutt3rz View Post
    Once you go synthetic you're not supposed to go back.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    May 2005
    Phillytown, PA
    Quote Originally Posted by Drews View Post
    Not true according to any publication on oil I've read.
    Dec 2003
    Dallas, TX / Sterling, VA
    I prefer not using synthetic oil.
    Registered User Chrisfit's Avatar
    Jul 2009
    rva
    Quote Originally Posted by brfatal View Post
    Any particular reason, or strictly preferance?
    Registered User Liquidr1's Avatar
    Oct 2008
    Greensboro, NC
    myth.
    every car iv had i have ran different types of oils. and iv went from dino oil to synthetic and back to dino and its never hurt anything.
    2009 Impreza WRX Hatch.
    Cobb AccessPort: Cobb Protune @ Draco Performance
    346 ft/lbs 289 awhp.
    Perrin CAI.
    Perrin Performance Catback.
    Perrin Performance 3" catted downpipe
    SPT boost guage.
    Jul 2004
    Seattle, WA
    Me too, but that's just because I'm cheap
    Dec 2003
    Quote Originally Posted by Chrisfit View Post
    http://www.blackstone-labs.com/faq.php
    Quote Originally Posted by Blackstone Labs
    What's the best oil to use?
    Ah, the million dollar question. We are an independent lab, so we don't make recommendations. It has been our experience that oil is oil, and either petroleum or synthetic-based oil will work well for just about any engine.
    Come on, you're holding out on me. I should use synthetic, right?
    Buddy, you should use whatever you want. Synthetic oil won't guarantee a longer engine life any more than my eating organic food will guarantee I'll live until I'm 90. We here at Blackstone generally use regular petroleum-based oil because honestly, it works just as well for us.
    And problems tend to happen when I do use synth.
    Registered User Bahamabob's Avatar
    May 2005
    Bridgewater, Ma
    I switched to syn at 10k, started getting oil use. I also got a little seepage on righthand cam cover. After 30k I switched back to dino. Now I have 133k on engine and it is hardly ever low. I do change oil within 3500 mile each time. Staying with Dino.
    Moderator timber's Avatar
    St. George, Ut.
    I have used regular old dino based oil for just about 200,000 miles. Keep it fresh, and you'll be fine. Also, if I remember correctly, SD_GR is an oil guru..so whatever advice he offers, I would take.
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    Registered User minato's Avatar
    Mar 2009
    Montana
    Synthetic is normally thinner than dino, hence if the engine is worn more oil will find its way past rings and seals, giving the illusion that the synthetic oil caused the leaks. If your engine is well maintained and in good condition switching back and forth is no deal. Synthetic oils hold up better to prolonged heat, and flow better at low temperatures. If you drive in such a manner or conditions that these are frequent factors, then consider the synthetic oil
    Quote Originally Posted by minato View Post
    Any two fluids of the same viscosity will, well, have the same viscosity regardless of their source or even composition. Whether an oil is synthetic or not does not make it thinner than another oil.
    I tend to agree here. The issue is the detergent packages and how good a solvent each oil is. If the old oil coked up crud and that formed a pseudo-fix at the point of a seal or gasket failure, and the new oil dissolves the crud exposing the existing failure, then a leak will develop.
    Moderator Donkey's Avatar
    Da boonies
    There is a reason synthetic oil has a higher flashpoint than dino oil. Its all in the MSDS sheets. For turbo application I would absolutely use synthetic over dino due to much higher combustion chamber temps and possible turbo coking issues. Plus the fact that most group IV synthetic can easy handle 7,500-10K oil change intervals.
    2002 FORESTER S
    1998 FORESTER S
