Okay, here's the deal. My brother and I changed out my rear brakes a couple months ago. Adjusted everything properly and after the initial wear in (a little scrubbing noise from pads while driving) I still get the noise in a turn, either direction. We took them apart again and I see no evidence of rubbing or improper wear. Now I did use after market discs and pads. The duralast brand from autozone, if that makes a difference? The only real difference from the factory is the duralast does not have the set screws. But I can't imagine that making a noise like that. The wheels bolted on in place should keep everything together. Any weigh ins? Thanks.
