Results 1 to 13 of 13
This is a discussion on grinding in first gear? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey gang. i have an 04 wrx. when i am at a complete stop, and push the clutch in to ...
    Jul 2008
    sussex county, new jersey
    hey gang. i have an 04 wrx. when i am at a complete stop, and push the clutch in to the floor, the gears sometimes grinds when i put it in first. everything in it is bone stock. no aftermarket parts. any ideas on what this could be?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by kord9 View Post
    one of 3 things... Your clutch is going out. Your clutch throw isn't adjusted properly. Or your 1st gear synchro is going out.
    How many miles on it? Original clutch?
    Moderator Donkey's Avatar
    Da boonies
    /\ what he said. First gear has always been a common problem. Also try checking/flushing the hydrolic clutch master cylinder and tranny fluid.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2008
    i just got the car on thursday. it had one owner. it is on the original clutch and has 66k.
    Nov 2006
    Denver Metro Area
    Clutch is probably going out. Do you know how to check whether or not the clutch is going out? There are a few simple ways to check for it.
    Jul 2008
    no i dont know anything about maintenance with cars. im hoping to learn alot on this forum. what are the simple ways to check if the clutch is going out?
    Nov 2006
    Denver Metro Area
    How to Tell If Your Clutch Is Going Bad | eHow.com
    In addition, if the clutch is fully engaged, and you punch the gas in a higher gear at a low speed (try 3rd at 15mph), and the engine RPM increases without the car speeding up, and you smell an acidic pungent odor, then it's probably the clutch
    Registered User jcsti's Avatar
    Aug 2009
    Roc, NY
    didn't you notice this problem when you before you bought the car and test drove it....
    Flirty User That's Younger Than the Chunks of Corn in Brian's Crap
    WRXie's Avatar
    Mar 2009
    Down South
    So I guess I should check my clutch too .. I always attributed it to the fact that I didn't push in the clutch far enough ..
    2002 WRX Yellow Blaze
    Bugeye Mafia #216
    High Mileage Club
    Jul 2008
    no it didnt happen when i test drove it. i also had my buddy who is a mechanic drive it and it wasnt happening. i tried that thing you mentioned about shifting from 1st to 3rd at 15mph and flooring it. nothing happened. the car just kind of bogged and slowly accelerated. but the RPM's didnt go up. i thought maybe at first i wasnt pusing in the clutch all of the way. i had a 97 ford escort before this and that has a cable clutch. so i figured i just needed to adjust to the hydraulic clutch. but i have sat there with my car parked, pushed in the clutch, put it in gear and it would still grind. i noticed it really only happens if i put it into 1st rather quickly. so i try to take my time in doing it.
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    sorry to slightly threadjack but i have a related question.
    When accelerating in first then having to slow again (two stop signs close together) i push the clutch in and leave it in first when as i slow. While doing this there is a whining noise (sounds like the synchros) but no grinding. Could this mean my syncros is going? If so how is that fixed?
    I would have started a new thread but it seems like that could relate and help the other questions present in this thread
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Nov 2006
    Denver Metro Area
    You're fine buddy.
    If your synchro is gone there will be grinding between gears, and you'll have to rev-match to get it into gear smoothly.
    Apr 2009
    CO
    You're fine buddy.
    just what i suspected and wanted to hear, Thanks. and op, good luck with your issue
    Mods
    Pics
