Results 1 to 15 of 19
This is a discussion on Issues with front end... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well after 6+ years with my 03 Wrx with 95k I am starting to get some front end issues... I ...
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    Well after 6+ years with my 03 Wrx with 95k I am starting to get some front end issues... I replaced struts all around with upper and lower top hats... My car is lowered on S techs. Been in the car for 4 years.. I think it's time to replace some bushings etc.. But my question is I don't know what or where to start.... I was hopping I could get a local guy test drive my car to put me in thr right direction...... Evoeater anyone in the area... Thanks jeff.. I live in the delco area
    Aug 2008
    Kennett Square, Pennsylvania
    hmmm...Lets see..what kind of "issues" are you experiencing? Noises, Vibrations etc etc....I'm assuming when you say "top hats" you mean upper strut mounts?...
    Nov 2003
    philly
    Yes top hats... No vibration it's more cluncks and bangs... I checked the axles no tears... I have the stock sways they could be bad... The steering rack or bushing could be an issue... I changed the belts. My stock struts where trashed so I am not sure if they trashed the springs
    Aug 2008
    Do you get this noise only when you go over bumps? Does the vehicle feel any more unstable than usual in turns? I would hop under there and do a thorough visual/check over of the entire front end....shake down the tie rods, ball joints, wheel bearings....bad ball joints can make a hell of noise similar to defective strut mounts..
    Nov 2003
    philly
    I'll have to check on the ball joints..... It's over bumps uneven ground... I am even pushing to see if I have a bad motor mount trans mount.... That's why I ask if someone on this fourm could look at it....
    Aug 2008
    Usually if you have a bad motor or trans mount you would notice a clunk on acceleration or somewhat of a knock when your idling and you rev the engine...
    Registered User SilentRevolt's Avatar
    Oct 2009
    Florida
    just a suggestion, check and make sure the bolt on the strut mount is completely tightened, if it's not and the strut loses pressure ie, when the tire drops, and it comes back up, the little nut on top clanks against the support.
    Nov 2003
    philly
    I tightened the top nut before it wasn't loss.... Evoeater if ur not busy and want to drive it I'll meet u tommorrow.... I just need a direction to go in.... I have no clue...
    Aug 2008
    I would be happy to drive the vehicle and try and determine the location of the noise.....I live around Longwood gardens are you familiar with Kennett Square or West Chester at all? ....
    Nov 2003
    philly
    PM sent with my cell #
    Aug 2008
    I checked for recalls and TSB's for your vehicle and unfortunately I couldnt really locate anything specific to your the noise we heard...There is one for the Spring seat in which apparently your supposed to install and insulator so the spring doesnt make noise..however that really doesnt seem like sound we heard...FWIW..I belive the strut to body nuts are 14mm and the strut nut is a 17mm
    Nov 2003
    philly
    Thanks alot AJ.... Thanks for the or u put in checking my car out... I'll order the tophats tommorrow... With longer exhaust brackets... Guys aj is a stand up guy it's great to have people like him around this community....
    Nov 2009
    Timing prob.
    (EJ20H engine)Hey does anyone know what could be wrong with my timing, I made sure the cams were off from eachother and lined up the marks, its a four cylinder quad cam, or twin on each head, I put it all back together and its turning over without any knocking sounds and sounds like it could start but its not, Could I have the cams on the exact opposite rotation of the valve inlet and that could be stoping it from firing?
    Aug 2008
    Quote Originally Posted by 4cyturbowrx View Post
    Hey thanks a lot man!..Jeff is a good guy also ...exhaust brackets def a good idea...as for the upper strut mounts..no guarantees that will fix your problem, however like I said if it was customers car I would order new 4 new ones...Let me know how it turns out dude...
    Aug 2008
    Quote Originally Posted by mellow45 View Post
    Ultimate thread jack buddy...lol..no worries..hmm..what year is the vehicle? How many miles? What model? What was the original reason the engine was apart? Try this tutorial here and triple check your marks... http://endwrench.com/images/pdfs/2.5Timing.pdf
