Results 1 to 13 of 13
This is a discussion on rear defroster causes bad radio static within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have an 07 wrx. when i use the rear defroster my stock radio signal is all static. i am ...
    Registered User irvin787878's Avatar
    Jun 2009
    Milesburg / Near State College PA
    i have an 07 wrx. when i use the rear defroster my stock radio signal is all static. i am guessing that the rear defroster and radio antenna together in the rear window is the cause for the static. mostly use my satellite radio with the fm transmitter till i get my new system installed. it also does it with the regular radio stations. my question is anyone else have this problem? can it be fixed? how to fix it? when i install my new system once i get the rest of the items needed will i still have this problem. thanks for the help.
    Registered User 06_wrxwago's Avatar
    Aug 2009
    South Jersey
    i have an 06 wrx wagon and my radio has been static since i got it....i too am trying to figure it out.
    i dont recall ever having the defrosters on though
    Jun 2009
    i have only had the trouble when i use the defroster. i really noticed it about the last month cause i have had to use it about every morning going to work.
    Aug 2008
    Kennett Square, Pennsylvania
    one of the grids is possibly broken on your rear window....when this is broken it will mix around the radio signals..there was a TSB about this I believe I read not to long ago...
    Jun 2009
    can you tell by looking at it if there is a grid broken. everything i found searching had nothing to do with the defroster just tint. i dont have any tint so thats not a problem. thanks for the help so far
    Aug 2008
    No prob man..you can sometimes look very closely and see if it is broken..or the next time you use your defrost see which line of the grid isn't working..you can also check the grid with a volt meter..you should have 12.6V available to the grid on each line with the defroster on...check across the grid so when/if you get a reading of less than battery voltage you will know where (if) it is broken...This is the first place I would start...Considering there is a TSB on it... Am I correct to assume without the rear defroster on the radio works normally?
    Registered User Merk247's Avatar
    Feb 2009
    catskill ny
    i just fixed a vehicle today with the same problem if you dont have tint u could use a multimeter or what i found works great take steel wool roll it up and drag it across the grid while its on if its broken even if you cant see it it will spark and burn the wool a lil and smoke
    If you have everything under control you're going too slow.
    Bugeye Mafia #218 XPT gm bcs stage 2
    my mods
    HIGH MILEAGE CLUB
    ASE CERTIFIED MASTER TECH.
    Jun 2009
    yes the radio is works perfect when the defroster is off
    Quote Originally Posted by Merk247 View Post
    thanks
    thanks alot for the help i will try these suggestions after work tomorrow and i will let you know what i find
    Aug 2008
    Good Idea, thanks for the tip man... I just recently learned that you can start an immediate fire with steel wool and a 9v battery..lol..not to get off topic here or anything..
    Sep 2009
    hudson valley, NY
    my 07 does this as well but considering how little I use the fm radio I've decided to be lazy and leave it.
    -Dan
    2007 WRX TR
    Jun 2009
    ok i tried the steel wool cause my meter is digital and the battery was dead. but anyway the steel wool gave me sparks in 2 of the gids in the lower corner on the driverside. how do i fix it is it hard to do and expensive. my car is just over the factory warrenty but i got the extended i think i will check to see if it is covered but knowing my luck its not. any help would be great thanks alot in advance.
    HAWK-EYE ALLIANCE #7878
    2007 WRX TR
    My work in progress. http://www.clubwrx.net/forums/off-to...ld-thread.html
    Aug 2008
    you can buy kits from NAPA and such..I believe Permatex makes a kit to repair it..
    Jun 2009
    ok thanks i will look into it after i call the dealership thanks for the help
    2007 WRX TR
