Helpppp
Results 1 to 10 of 10
This is a discussion on Helpppp within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Today i got into my wrx to back out of my drive way and once i turned the wheel to ...
    Registered User JoeyFTW's Avatar
    Oct 2009
    Franklin,NJ
    Helpppp
    Today i got into my wrx to back out of my drive way and once i turned the wheel to a certain point it became hard to turn and a belt squeeled,not to loud but enough to catch my attention. Im pretty sure its power steering just want other opinions. And if it was my steering rack what other symptoms would my car have?
    Jan 2005
    Eh, whaaaaa?
    Check fluid levels and quality. Might need a fluid change. Get that done quick because it can ruin the pump rather fast.
    Oct 2009
    Franklin,NJ
    yeah? anything else that i should really look out for?
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by JoeyFTW View Post
    Nothing that I can think of, though it could be something binding, but I'm thinking it's more pump/fluid related than steering rack, and it's relatively cheap and easy to check and replace steering fluid so that's where I would start.
    Aug 2008
    Kennett Square, Pennsylvania
    Personally, along with checking your fluid level and condition I would be checking the tension and condition of your P/S/ALT belt...How many miles are on the vehicle? Have you had the P/S system open recently or any other work performed on the vehicle?
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    My bet is on the fluid needing to be flushed or the hoses taking a dump (which you can tell by the hose).
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Oct 2009
    Franklin,NJ
    im gonna go out in a little bit and check the fluid,i do know that i recently threw some P.S fluid in there cuz i was runnin alittle low,but i will still check the fluid level. if i have to flush out the system do i have to take it somewhere or is that somthing i can do in my driveway?
    Oct 2009
    Franklin,NJ
    I FIGURED IT OUT
    Well guys thank you for all the help but i walked outside,popped the hood and there sitting on the top of my motor was a shredded piece of my belt. And because im such a great mechanic i figured out that THAT is the problem! LOL How does somthing like this happen? i have 65k miles on the car, maybe it was time to get a new belt? or is there somthing else that could cause it,pulley maybe?
    Jul 2008
    San Antonio
    Look at the rest of the belt to see if it was time to be done. 45-50K in extreme conditions is when the belts need to be done. Glad you found out what it was.
    N-swinger
    2000 Escort
    Oct 2009
    Franklin,NJ
    Well thanks once again guys for the help, i went out got a new belt and threw it on and everything is up and running smoothly! it was an easy fix,it took me longer to get the pain in the neck cover off the top then it did to finish up the entire job lol. thanks again!
