Yeah, your probably on the right track. Pull off the intercooler and look for oil - there is typically some residue or maybe a little that you can dump, but definitely not a puddle. With that off you can get to the PCV, I'd just replace it. You can pull the DP and see if the turbo is leaking out that way (maybe let it idle for a few minutes first in case it is all burning off during normal driving). You can also pull the plugs and see if there is oil on any or all (any would be more likely an internal problem, all would be external). They are a bit of a PITA to get to but if you take them out you can do a compression test as well.
LinkBack URL
About LinkBacks
It's not a puddle or even that bad I just didn't know what to expect. Also switched to 10w30. No smoke at all this morning and the exhaust smells cleaner. I give it a couple more days before declaring victory, and maybe check the plugs and DP this weekend just 'cause.
