Code P0442 help?
Results 1 to 8 of 8
This is a discussion on Code P0442 help? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well today I recieved a check engine light with the code P0442 my Cobb AP stated it was "Evaporative Emission ...
    Registered User AsILayDying's Avatar
    Dec 2008
    Central Florida
    Question Code P0442 help?
    "Evaporative Emission Control System leak detected (small leak)"
    What exactly is this and what can I do to check or fix this on my own. Any suggestions. Thanks
    BlobEye Syndicate #-666
    Stage II 04' WRX Black (Performance Race Solutions Tuned 310whp)
    "its never enough"
    May 2007
    orlando flawduh
    did you check your gas cap to make sure it's properly tightened?
    if yes, thennnnn i'm trying to find some more answers on nasioc right now. i'll post back if i find anything else
    desiree
    Dec 2008
    Central Florida
    Quote Originally Posted by wrxtreme06 View Post
    wrxtreme06 I have to say you are one of the nicest auto-enthusiests I have met. You are always eager to help. I really do appreciate it very much. I will try the gas cap trick and see if thats it. Thanks again.
    "its never enough"
    Moderator Donkey's Avatar
    Da boonies,Va
    Might be one of the EVAP solenoids. One on the manifold and one under the trunk by the charcoal box.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2008
    Central Florida
    Yeah wish I could say I knew enough to know exactly what I was to be looking for, but I really dont. So maybe a quick photo of the location or solenoid that Im lookin for would be a huge help. Thanks.....
    "its never enough"
    Aug 2008
    Kennett Square, Pennsylvania
    What year is this vehicle? How many miles? .... If you have the means I would smoke test the system if you find nothing with a visual inspection.When you tighten your fuel filler cap check the seal and make sure it isn't dry rotted/torn....The canister purge solenoid is located to the left of the alternator ( when viewed from the engine) you will see a couple vacuum lines coming off of it and an electrical connector... I've seen many times when people are in the engine modding whatever there modding (intake,FMIC etc etc ) they move the solenoid a tad and it cracks/breaks off one of the nipples...the vent control solenoid is back by the canister in the passanger side "muffler well"...If either of these actual solenoids go bad it more than likely throw a EVAP control system malfunction code...Have you had the fuel pump or fuel sender out recently? I've also seen people who throw in a HO pump or whatever..during reinstall they bend the gasket for the pump over and tighten the nuts not realizing it and this sometimes throws a leak code...
    Dec 2008
    Central Florida
    Ok the vehicle is a 04' WRX Sedan Stage II Cobb AP, it has
    57,xxx miles and no I have not had any parts out recently or new ones installed. So I will look at these locations this morning. Thanks for the help. I hope this is an easy fix.
    "its never enough"
    Da boonies,Va
    Quote Originally Posted by AsILayDying View Post
    If you search "P0442" on NASIOC alot of threads will come up with pictures and solutions........
    2002 FORESTER S
    1998 FORESTER S
