Results 1 to 2 of 2
This is a discussion on Noob w/ Bugeye lighting problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Recently my tail lights and foglight both went out and my driverside headlight come in and out (I tap the ...
    Nov 2009
    Recently my tail lights and foglight both went out and my driverside headlight come in and out (I tap the headlight and it lights up)
    My question is: Is there a relay that needs switching out and where is it?? Also I switched the fuses to no avail, it wouldnt hurt to make sure I switched the right ones.
    Thanks from nooberville and thanks for the help
    Moderator Donkey's Avatar
    Da boonies
    If you tap the ehadlight and it comes on,it is not a relay issue as obviously power is there. The bulb could be going bad or the socket is corroded or loose. For the tail lights and fogs I would test them with a multimeter before just swapping stuff out. But that would sound like a relay problem. Wiring diagrams are in the factory manuals.
    Factory Service Manuals
    2002 FORESTER S
    1998 FORESTER S
