Results 1 to 15 of 22
This is a discussion on RPM spike when getting out of gear within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This apart from the other power loss issue I'm having right now has been happening for a while, actually, since ...
    Registered User WagonGuy's Avatar
    Sep 2005
    Chicago
    This apart from the other power loss issue I'm having right now has been happening for a while, actually, since I remember. It doesn't happen all the time, every time, but sometimes when I change grears (~3500 - 4000 rpm), right after I press the clutch and let the gas pedal off, the rpms jump up another 500-1000 rpms and then normally fall down.
    That doesn't seem normal. Has anyone else experienced something like that?
    Blobeye Syndicate #1337
    man vs technology blog
    MvT@YouTube
    Registered User AsILayDying's Avatar
    Dec 2008
    Central Florida
    Well I am interested in the answer or suggestions to this cause I experience this as well. I always think maybe it was me leaving my foot on the gas to long so when it happens I try it again to make sure to take foot off before even touching clutch and it still does it. Same RPM area as well. Doesnt happen all the time but frequently enough to not be right. Hope someone knows an answer......
    BlobEye Syndicate #-666
    Stage II 04' WRX Black (Performance Race Solutions Tuned 310whp)
    "its never enough"
    Aug 2008
    Kennett Square, Pennsylvania
    What year/model is the vehicle? There is a reprogram available for the newer model outback/legacy models for this exact same concern.....
    Sep 2005
    Chicago
    Mine's a stage 2 05 wagon and AsILayDying's is a stage 2 04 sedan.
    And I think we are both pretty much 'reflashed'
    MvT@YouTube
    Dec 2008
    Central Florida
    Yep, reflashed running stage II Cobb map. 04' WRX Sedan. Wonder if anyone has an idea cause I dont want to bring it to subaru. They will just tell me they cant replicate the problem and to bring it in when it does it again. Problem is it doesnt do it all the time. So any help ideas or advice would be helpful
    "its never enough"
    Registered User Lavid2002's Avatar
    Oct 2009
    HEYYYY!!! I was just thinking about this the other day...heres my theory. The turbo is pressure fed into the intake right? When you let off the gas the engine is still cycling....so although the engine isn't getting fed fuel and it doesnt have a power stroke it is still being fed pressurized air that makes the engine rev up a lil....
    Im very very new to cars so this is probably very very wrong...hahaha but thats my n00b theory. Interested to see what causes this too.....
    P.S. I'm BONE stock...I just have a screen in my hood scoop protecting my OHIC thats it
    D-$
    Blobeye '05
    Moderator Donkey's Avatar
    Da boonies
    It's normal. Some say it's the ECU and some say its the turbo. I know it generally only happens to me under light boost. Under vacuum or heavy boost it doesn't happen. I read some info on NASIOC that explained it but I can't find it now.
    2002 FORESTER S
    1998 FORESTER S
    Sep 2005
    Chicago
    Quote Originally Posted by Lavid2002 View Post
    It only happens under a moderate boost of -2 to 5 psi so I don't think it's enough pressure to really propel the pistons. Besides, the BPV is supposed to take care of the extra air pressure and recirculate it.
    Only under low boost and only randomly, every time, all the time.
    Another one of those things that makes a Subaru, a Subaru
    MvT@YouTube
    Dec 2008
    Central Florida
    Ok Im gonna wake up a semi-old post. I have been experiencing this RPM spike after cltch goes in to shift to next gear if I shift at 3500 to 4000 it skies to like 5500 and then very slowly settles to like 2000 or 2500 which is extremely irritating. It only happens every now and then, and when it does happen it just magically dissapears like there was never an issue. Please some one hopefully an idea of what this could be. Thanks
    "its never enough"
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    i was always under the assumption that when your RPMs jump up like that, it means your clutch is on its way out.
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Da boonies
    That would be the tale tell sign of a worn clutch.............
    2002 FORESTER S
    1998 FORESTER S
    Dec 2008
    Central Florida
    Well I am almost 10000000% sure its not a clutch issue being that I just had my clutch replaced by Subaru a month ago. Its not while driving. Its while the trans is not engaged, out of gear sitting in neutral. Normal driving shifting from 2nd to third, let off gas push in clutch and RPM's sky, then settle down to 2500 to 2000 and sit there and sometimes rise for no reason. Hope this helps.
    "its never enough"
    Da boonies
    Could be the cruise control cable or vacuum leak. Diagnosing vehicles over the interweb isn't the easiest thing...................
    2002 FORESTER S
    1998 FORESTER S
    Dec 2008
    Central Florida
    I understand that its almost impossible to give perfect advice or help, but I appreciate the advice on what to look at or what to check so I will check the CC cable and for vaccum leaks tomorow after my uppipe gets installed. Thanks for help, by the way, last time I had the RPM spike it was because of a clutch and you were right. But that was a completely different spike, I could tell it was slipping. Again thanks for the help.
    "its never enough"
    Sep 2005
    Chicago
    Quote Originally Posted by AsILayDying View Post
    What happened to your old clutch?
    MvT@YouTube
