Brake light issue
Results 1 to 5 of 5
This is a discussion on Brake light issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 WRX wagon and the rear brake lights, including the led in the window, are no longer ...
    Sep 2003
    Brake light issue
    I have a 2002 WRX wagon and the rear brake lights, including the led in the window, are no longer working. I checked the fuse and it seems to be ok. Any other ideas?
    -mx
    Jan 2005
    Eh, whaaaaa?
    MIght be the switch in the pedal assembly.
    Jan 2005
    Eh, whaaaaa?
    Not sure where the connector is for it, but if you connect your multimeter to pins 2 and 3 (2 is top left if you hold the connector with the tab on top, 3 is bottom right), you should see less than 1 ohm resistance with the brake pedal not depressed, and with it depressed you should see greater than 1 Mega Ohm.
    Found a diagram, it's B65 as shown here:
    Man, I just love electrical problems.
    Sep 2003
    Thanks. I'll check those.
    -mx
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by motoxpress View Post
    -mx
    How many miles are on the car vehicle? I know this might sound like a long shot but did you check all the bulbs? I had something similar to this on my Legacy and I had like 4 bulbs out back there..Something simple to check...If no bulbs are burned out back there I would be checking for power and ground at each connector while the brake pedal is depressed...than go from there as mentioned...
