When it rains
Results 1 to 7 of 7
This is a discussion on When it rains within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys I'm wondering if any of you have had my experience. It seems like whenever ever there is a ...
    Registered User shello007's Avatar
    Nov 2008
    Newark, Delaware
    When it rains
    Hey guys I'm wondering if any of you have had my experience. It seems like whenever ever there is a huge amount of rain, my car will sputter after being parked for a while. In the first couple instance of it happening, it would sputter, buck and hesitate (Like a bad misfire,) when it gets to 4000 rpm. Yesterday after sitting in the lot for the duration of my work shift ( I drove to work in the rain also) it would tumble and then shut off, as if it was starved for air. In order for it to keep Idling I had to press the accelerator and it started to sputter. Sounded like water was mixed with the fuel or the plugs were fouled. I have no mods, except for an SPT intake and silencer delete. I took off intake filter to check for any noticeable amount of moisture, but nothing to phone about. Please Help guys/ gals.
    Registered User DC.R3X87's Avatar
    Aug 2008
    Lancaster, PA
    hope this helps
    the same thing happened with my car i took it to the garage and the guy said i had some water in my gas lines. it was in the middle of winter he asked me if i drive with less then a quarter tank often, and i did being a poor college student. he told me condensation forms in the gas tank and mixes with the gas causing the water in the gas lines. he flushed the lines and the car worked fine ever since. so now in the winter i dont let it go passed half
    Nov 2008
    Newark, Delaware
    Rain
    Thanks man. The strange thing is the tank was full. Will try adding a fuel system cleaner on my next fill up. Anyone knows if redline is safe to use on our cars?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I'd put money on the intake getting wet.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Moderator Donkey's Avatar
    Da boonies,Va
    Yep. Common problem with people that have short ram intakes with the filter close to the fender wall. When it rains hard water makes it into the channel between the fender and hood. Ends up making a wet spot on the filter and once the car is started it contaminates the MAF sensor.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2008
    Newark, Delaware
    Gracias
    Hey Sinister and Donkey, I think you guys may be right. I really appreciate your imput. (You to R3X387) I think by removing the snorkus the water has no where to go. The end of the snorkus delete tube ( that enters the engine bay) sits below the filter, but I guess some spray ends up on the filter. ?uestion. Those little episodes I had, is that the start of any detrimental effect or the fact that its running well again means it's ok?
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by shello007 View Post
    it's not from spray coming up from the wheel well... it's from the rain draining between the hood and the fender and landing on your filter.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
