Im assuming your talking about the check engine light coming on? The next time you see it go get the code pulled or pull the code if you have a scanner. How many miles are on this vehicle? I would def. be ruling out a loose heat shield before you go digging into things...
LinkBack URL
About LinkBacks
. im just wondering if that can be from shaft play or bad waist gate or a crack possibly. please help!
