Results 1 to 9 of 9
This is a discussion on grease on inside of both front wheels within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I saw grease on the inside of both front wheels on a 2005 sti i'm thinking of buying.The cv boots ...
    Oct 2009
    Question grease on inside of both front wheels
    I saw grease on the inside of both front wheels on a 2005 sti i'm thinking of buying.The cv boots looked good.what could be causing this? The car is immaculate otherwise and nothing seemed bent or cracked.
    Registered User ScubieSubie's Avatar
    May 2008
    SoCal, CA
    take off your wheels and fully inspect the cv boot and axles. If it doesnt look torn, maybe the clamp/o-ring came off the boot causing it to leak
    Jul 2008
    San Antonio
    Sure it's grease and maybe not brake fluid.?
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Registered User Jusino's Avatar
    Jan 2009
    Holyoke, MA.
    maybe the previous owner did maintenance and over greased it... and then driving around it just splattered on the wheels due to sintrifigal force... lol
    MANNY
    HAWK-EYE ALLIANCE #134
    https://www.facebook.com/L1G3R
    2007 WRB WRX TR, Stage 2.5, SPT Intake, Full Invidia 3" Exhaust w/ N1, ISC Coilovers, 17x8 RPF1 w/ Hankook VENTUS V4, DIY Engine Grounding.
    Registered User 06WRXturbo's Avatar
    Nov 2006
    VA
    Sounds like the outer cv boots are split/torn and throwing grease. Did you check all 4 cv boots up front?
    Registered User bigg1115's Avatar
    Oct 2009
    cv boots
    defanatly cv boots split mines the same at the min
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    The spelling Nazi has been alerted to this thread!
    Quote Originally Posted by Jusino View Post
    Centrifugal
    Quote Originally Posted by 06WRXturbo View Post
    Sounds like the outter cv boots are split/torn and throwing grease. Did you check all 4 cv boots up front?
    Outer
    Quote Originally Posted by bigg1115 View Post
    Definitely
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by Trainrex View Post
    Centrifugal
    Outer
    Definitely
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Awesome!
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    08 Candy White MK5 GTI 6spd
    Moderator:Tri-State and Transmission & AWD forums
