ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 10-18-2009, 06:16 PM   #1 (permalink)
need a lil help with my 02 wrx
for the past couple days ive noticed my car starting to run hot if i sit at idle for more than a couple minutes and was wondering if it maybe the thermostat? once i start driving again it goes straight back down to operating temperature. i checked all the fluids and topped the coolant off and its still doing it. i just figured i would ask other opinions before i start replacing anything and maybe save some money thanks btw its got 116k miles and the motor is stock except for a tbe
wrxyo is offline   Reply With Quote
Old 10-25-2009, 08:04 AM   #2 (permalink)
Quote:
come on i really need some help
Old 10-25-2009, 08:09 AM   #3 (permalink)
wrxlaunch's Avatar
sounds like thermostat
__________________
Elapsed Time = 13.986 @96.11mph, RT=0.08, 60'=1.938,
02 Wrx: Turbo XS Up-Pipe,Spt intake,mbc set to 1bar and Turbo XS RFL axle back. 114xxx miles
wrxlaunch is offline   Reply With Quote
Old 10-25-2009, 08:31 AM   #4 (permalink)
Quote:
ok and is there a easy way to get to the thermostat to replace it? i know u can get to it while replacing the timeing belt but i really dont have the cash to do the timing belt right this second and was wondering if you could easily access the thermostat a different way
Old 10-25-2009, 11:15 AM   #5 (permalink)
DC.R3X87's Avatar
Send a message via AIM to DC.R3X87
replacing the thermostate is pretty easy except for the fact thats its located at the motor side of the bottom radiator hose so u need to drain all ur fluid to change it. there is a drain plug at the passenger side bottom corner of the radiator u can get to it just by removing the mud guard under under the car. then take your hose clamp off the hose on the motor side and drain the rest of the fluid. open the cap on the top of your engine when your draining it. the part where the hose attached is a 90 degree metal piece that has 2-3 screws holding it on i cant remember. remove the screws and the thermostate is right there. just pull it out rplace with new one and reassemble everything and fill back up with coolant. if everything goes right u can do it in less then an hour,i hope this helped i am sure there are some threads on here with some pictures.
__________________
http://photobucket.com/WRXALBUM
DC.R3X87 is offline   Reply With Quote
Old 10-25-2009, 12:41 PM   #6 (permalink)
EvoEatr's Avatar
before you go just replacing things....are your fans cycling on and off? when they do cycle are they blowing hot air? is the radiator full? Have you had any cooling system work done recently?..As others have mentioned chances are I would start off with the thermostat..after that I would prob. be leaning towards a clogged radiator... ( the thermostat housing should be 2 10mm bolts ) located directly below the D/S timing cover... This might be of some assistance... Impreza Manuals | ken-gilbert.com
EvoEatr is offline   Reply With Quote
Old 10-25-2009, 01:18 PM   #7 (permalink)
I was doing some research on it and read on how to "burp" the system so i went out to do it and when i removed the radiator cap i noticed the rubber gasket was ripped in half so i went and got another cap and burped the system and it fixed all my problems i appreciate your help thank you
Old 10-25-2009, 04:47 PM   #8 (permalink)
DC.R3X87's Avatar
lol yea i should have said that. i forgot my cap had a ripped gasket when i first got it and the system was loosing pressure and wasnt cycleing. good job with the detective work
__________________
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do you make the STi into a highway monster? RoadStar Everyday Impreza Talk 122 11-27-2007 08:28 PM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
