what is it? :(
Results 1 to 15 of 18
This is a discussion on what is it? :( within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I hear that voice from the rear, it can be the diff, brake shoes, braking plate, e-brake shoes or anything, ...
    Nov 2008
    what is it? :(
    I hear that voice from the rear, it can be the diff, brake shoes, braking plate, e-brake shoes or anything, I can't understand. It vas much less but now after 10k km it sounds louder
    YouTube - subaru rear voice
    Dec 2003
    Dallas, TX / Sterling, VA
    Sounds like a bad wheel bearing.
    Registered User Jusino's Avatar
    Jan 2009
    Holyoke, MA.
    Quote Originally Posted by brfatal View Post
    sounds like a bad wheel bearing.
    +1
    MANNY
    HAWK-EYE ALLIANCE #134
    https://www.facebook.com/L1G3R
    2007 WRB WRX TR, Stage 2.5, SPT Intake, Full Invidia 3" Exhaust w/ N1, ISC Coilovers, 17x8 RPF1 w/ Hankook VENTUS V4, DIY Engine Grounding.
    Nov 2008
    I have installed new brakind pads, new rear wheel bearings and changed diff oil wit eneos 75w90. No result at all :-(
    I have checked wheels and they cant tuch anything up there. Wheels are yokohama s.drive 205x50 r16 with facktory rims
    Dec 2003
    Nov 2008
    can it be the CV joint? I know how sounds dead front cv joint but what about rears?
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    You know what else sounds like that ?
    Do you have directional tires ?
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Nov 2008
    yes, tires are directional, yokohama s.drive.
    I don't know what it can be. at first it started annoyng sound on when cornering hard to the left. now I hear it on any cornering and a bit when driving straight
    Jul 2004
    Seattle, WA
    Quote Originally Posted by bako View Post
    From this statement I would say it sounds like Passenger Rear Wheel Bearing.
    If the rear CV joint failed it would make the same noise as a failed front CV joint when going strait.
    pzr2874 was trying to ask if your tires are mounted in the correct direction.
    Registered User 08SubieWrx's Avatar
    Mar 2008
    South Jersey
    Run your hand over your tire and see if it feels choppy. Tires make a lot of noise when they get chopped..
    Dec 2003
    Quote Originally Posted by 08SubieWrx View Post
    Choppy tires do not fit with the symptoms he gave.
    Registered User 2ndSuby's Avatar
    Feb 2009
    Bloomington IN
    My 99 2.5 RS Imprez made noise at cornering from the shroud on the rotor scraping in a hard corner had to realign/CUTOFF ... something to check ...
    Jul 2008
    San Antonio
    I was trying to rule out, BUT my friend had a messed up tire in the middle of the tread and took it to Discount Tire and they showed him tread seperation... So, go get your tires looked at too. Sounded just like a bearing issue.
    Are they all going the right direction though ?
    N-swinger
    2000 Escort
    Nov 2008
    I have rechecked tires, everything is all right. Yes, they may have some internal damage which cant be seen with inspection but i dont think so. I have checked diff cv joints and i can move it for about 0.5mm on any direction. Maby dead diff bearing?
    Mar 2008
    South Jersey
    All he said was that there was a noise in the rear... I've seen hundreds of chopped tires make a lot of noise while I was a tech for Nissan.. I was at work before and didn't see the video till I got home and only read what he wrote, but I've only heard tires that loud a handful of times (usually flat spots or ridiculously chopped tires could get that loud).. so I'd have to agree and say its most likely a wheel bearing.
