| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here! |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
Help with timing belt replacement and Service manual
I have 100k on my 04' WRX non Sti. I am having a hard time finding a service manual.
Where can I find one? All I can find are one's that say for the STI model. Also, I need to do the timing belt. How would you rate doing the job? difficult, easy? It seems that if you drop the fans you would have plenty of room to work since the timing cover is in the front. Or what have you paid to have subaru do the timing belt? What would i need to do the job as far as special tools and gaskets and parts? Thanks in advance for your help |
#3 (permalink) |
The timing belts on these cars aren't too bad..As long as you know what your doing...If you mistime the engine you will bend valves....the first time I did a Subaru DOHC t-belt job I used this article as a tutorial... http://endwrench.com/images/pdfs/2.5Timing.pdf
#5 (permalink) |
The timing belt replacement isn't that bad. I believe you should be able to do this with out removing the fans or radiator.
__________________
JR - 95 STX 2007 Philly & SJR SCCA STX Champion Sponsored by JSC Speed My AutoX Build Thread: Teh Cone Dodgin' STX Wagon |
#8 (permalink) |
Timing Belt and Water Pump Replacement
^There is the tread I used to replace my timing belt. Very handy.^ I would rate the job easy to medium for difficulty assuming you have a good set of hand tools (ratchets, breaker bar etc.). It is tedious though. Definitely easier if you remove the fans and radiator. You always have the forum to fall back on if you run into trouble. Good luck, T.J.
__________________
150,000 mile club. Old Irish adage: "Do not resent growing old. Many are denied the privilege." NASCAR SUCKS. Last edited by T.J.; 10-12-2009 at 05:36 PM. |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 60,000 Mile Service - Timing Belt? | bluesramsrock | General Maintenance, Troubleshooting & Accidents. | 9 | 09-16-2009 04:01 PM |
| Timing belt | jeffmm06 | General Maintenance, Troubleshooting & Accidents. | 3 | 03-25-2008 09:23 AM |
| Me and my new 02 WRX Wagon! | Superorb | New Member Hangout | 19 | 12-13-2006 09:39 PM |
| 10% OFF With Service | FLAT4 | Mountain States | 34 | 09-24-2003 09:09 AM |
