On dash Brake Light
Results 1 to 4 of 4
This is a discussion on On dash Brake Light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Recently started this past week in my 04 wrx. Brake light stays on after taking off my Parking break. No ...
    Registered User corybb's Avatar
    Cape Girardeau, MO
    On dash Brake Light
    No rubbing. No noise. Brake is definitely disengaged.
    After like the 1st minute of driving, it will turn off at a stop, but turns back on once the car reaches 15-20 mph or often in between 1st/2nd gear shift.
    Later in the day or after extended driving, the light never comes on.
    On a side note, my parking brake has never felt very "strong" it often has trouble holding car on an incline (reverse especially). I always have to park with it in gear.
    Any Ideas?
    I've read some about fluid levels, or possibly needing new pads/rotors?
    It seems once brake or possibly fluid heats up the issue goes away. I checked and I dont THINK the fluid levels are down.
    Aug 2008
    Kennett Square, Pennsylvania
    Be sure about the fluid level before we go further..I would make sure the reservoir is full..after that I would be checking the switch by the e-brake...
    Cape Girardeau, MO
    switch? like a sensor?
    Registered User jrswrx69's Avatar
    Sep 2008
    powell tn
    its a switch that at the back to the ebrake assembly under the console it could have a loose connection or sticks as for the brakes no wanting to hold if pads are like new there is an adjustment for the ebrake right there under the console as well at least in the 02-03 and 06-07 models
