Changing Timing belt, what else should be changed?
Results 1 to 5 of 5
This is a discussion on Changing Timing belt, what else should be changed? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone, I'm about to get some maintenance done, i just hit 90k on the original belt. I have been ...
    Registered User Gwangsun's Avatar
    Nov 2007
    NJ
    Hey everyone,
    I'm about to get some maintenance done, i just hit 90k on the original belt. I have been running the car hard lately and don't wanna take a chance of the car dieing on me, I got the following ready to be installed.
    Timing Belt
    water pump
    tensioner
    crank shaft seals
    main bearing seal
    is there anything else i should replace while in there?
    Thanks
    "Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." -Albert Einstein
    Mods
    Cobb Stage 2
    If you see any juice coming out then replace that part. Also replace the external accessory belts, using authentic Subaru items.
    Aug 2008
    Kennett Square, Pennsylvania
    +1 ^..Take a feel of all the idlers and if any of them feel rough or are questionable..replace it. ( Of course some people prefer to replace all of them anyway while there in there, also considering this is a highly interference engine )..Also I was going to mention all 4 cam seals, however that may be what your referring to as the "crank shaft seals"..And the 1 crank seal which you may be referring to as the "main bearing seal"...Also It prob wouldn't hurt to remove the oil pump and tighten the backing plate screws ( they have a tendency to back out sometimes) reseal the pump, and replace the o-ring...
    Jul 2011
    are the 4 cam seals and the crank shaft easy to replace? note all is apart today for the belts/pump, etc replacement.
    thanks
    Quote Originally Posted by targawrx View Post
    Easy is such a relative term. I'd say feasible, but then again I am not mechanically skilled. Here is what ended up happening on my car in the link below. I got extra vise grips and used the old seals backwards to hammer in the new ones. A bunch of o-ring picks got broken removing the old seals.
    Cam seals, crank seal: Replacement? How?
