Results 1 to 6 of 6
This is a discussion on smoking like a cigarette out the hood scoop within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just bought an '05 WRX wagon with 85k miles. Here is the daily ritual. Start the car at 6:45 ...
    Oct 2009
    Tulsa
    I just bought an '05 WRX wagon with 85k miles. Here is the daily ritual. Start the car at 6:45 to warm up. Leave at 7:00. I have to drive about 3 miles to my son's daycare. The car never goes above 45 mph in this time. At about a mile and a half, I hit my first stop light. This is when the car fills with a burning oil smell and I notice light smoke out of the hood scoop. I continue on, and by the time I hit the parking lot and turn the car off, it is smoking about the amount as if a cigarette were sitting in the hood scoop. It is a light white color and smells heavily like either oil or burning rubber. By the time I drive another couple of miles to get to work, it is gone and done. This all happens with no drop in performance. It does idle a little rough sometimes. This burning is just happening on it's first run of the day. Dealership replaced the valve seals, but the problem persisted. They checked the turbo and pulled the down pipe. No oil. Please let me know if this is just normal or I need to take it back for what I'm sure will be time after time after time...
    It's not normal. Find the leak.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    totally off topic but any reason why you leave your car running for 15 minutes to warm up? that seems kind of extreme
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Baconator azWRX06's Avatar
    Apr 2006
    Gilbert, Arizona, United States
    Chances are you are leaking something onto the down pipe and after it gets hot it starts to burn. I had my inner boot tear on my 06 and sling grease all over the down pipe. Smells less than wonderful and at stops, smoked out the scoop. Do you see any faint smoke trailing behind the car? Anything dripping or puddling?
    -AJ | Hawk-Eye Alliance #55 | Stink-Eye Mob #1
    NASIOC - Narcissistic, Arrogant, Self Involved, Oligarchy of Cryptorchidisms
    2011 Chevy Camaro SS RS Package & 2011 Honda Pilot
    Used to have: Protune Stage 2 2010 Subaru WRX
    Used to have: Stage 4 2006 Subaru WRX
    Add me to Facebook
    Nov 2007
    Quote Originally Posted by machinehead75 View Post
    I had the same problem with my o5 wag. I bought it new and had what appears to be a similar problem. HOpefully your will be as easy to fix as mine. My transmission dipstick would not seat properly and would slowly back out and would allow some oil to hit the downpipe. Again, smelled awful and looked like the car was on fire out the scoop.
    my .02
    Registered User jcsti's Avatar
    Aug 2009
    Roc, NY
    i had a problem like this with my o4' wrx, i had an air intake installed and it was rubbing against my power steering line and it eventually rubbed through the metal and start leaking fluid onto my header which was creating white smoke out the hood scoop. I had to take it in and have the power steering lines replaced at subaru it cost around 500 bucks.. not sure if this helps but maybe check your power steering fluid levels...
