"Cig" lighter not working
Results 1 to 12 of 12
This is a discussion on "Cig" lighter not working within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my cigarette light is plugged in and the fuse is straight but some how there is no power getting into ...
    Registered User Infidel619's Avatar
    Sep 2009
    my cigarette light is plugged in and the fuse is straight but some how there is no power getting into it. any clue or suggestions?
    The Impreza does not have a cigarette lighter. The 12V power outlet is controlled by a fuse, and if that fuse is OK then check with a volt meter for power at the outlet. If you are trying to use a lighter in that outlet it may not be working due to the difference in circumference.
    Sep 2009
    i tried plugging in two different types of GPS power connectors into the cigarette lighter and neither worked. but i will see if there is power going into the outlet
    Dec 2006
    New England
    I have the same problem with an 04 WRX. It looks like the accessory power assembly will need to be replaced but I have no idea how to access the area without taking out the AC controls.
    What did you end up doing?
    Sep 2009
    still doesnt work, i was told by a place to go to a dealership..the manuel doesnt help either so. only thing i can think of. ill let you know what they say.
    Dec 2006
    New England
    My dealer wanted $180 to replace it which is why I decided to try it myself. It looks like it will be an easy fix if I could just get to the area. Unhooking the air / AC controls looks like a real pain.
    Aug 2008
    Connecticut
    I know on my 08 the power works fine, but cigarette lighters don't for some reason. Not really sure why.
    Sep 2009
    ya and every time people ask what kind of car, and you tell them, they right away say "and were off to a bad start" so ya.
    Aug 2008
    Connecticut
    It doesn't really bother me enough to do anything about it. I have regular lighters and the power works there, so..I'll live with it. Hopefully the next car will have one that works.
    Sep 2009
    ya, i wanted mine to work cause was livin in germany and drivin in the cities, so i needed it for the gps, and their street signs are literally hidden. but back here in the states i dont need it.
    Registered User economatic's Avatar
    May 2009
    Bend, OR
    Why not take SD's advice and get a cheap voltmeter to see if it is getting power? It would take all but 3 seconds to see if you're getting power. If it has power the dealership is going to charge you an insane amount for doing the same test.
    Dec 2006
    New England
    I was able to get the outlet out and found the problem. There is a fuze wire on the back of the outlet that is blown / melted. It seems like it offers some sort of redundant protection in the case that the normal 20A fuze doesn't blow.
    For now I have soldered on another wire but I'm thinking, to be on the safe side, I may pick up a replacement outlet and install it. Hopefully Autozone will have something.
    To get to the outlet I had to remove the stereo then unscrew the air/AC controls and push them up to where the stereo was. Then I was able to easily access the area by reaching under the air / AC panel.
