Results 1 to 8 of 8
This is a discussion on Problems with 06 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello guys, All of my modifications are located in my sig. The car was tuned at TopSpeed in Atlanta GA. ...
    Registered User Very-Rexy's Avatar
    May 2006
    Warner Robins AFB 30,000 feet
    Hello guys,
    All of my modifications are located in my sig. The car was tuned at TopSpeed in Atlanta GA. Now that that's outta the way, about 4 months ago I took my car to the 1/4 mile track and posted up a best time of 12.6 @111mph. Yesterday i headed back to the track and only had a best of 13.3@106mph. ??? The 60fts are the same for both runs, around 1.6-1.8. The car doesn't smoke at all, idles fine and no codes. I'm getting a leakdown test done on thursday. Only thing I have picked up on is that, yesterday, while I was going down the track the car was only hitting 17-18PSI max. But when I'm rolling on a road or highway I hit 20PSI, which was what I was tuned for. I'm not sure if that has anything to do with it but Im just throwing that in there. The car just broke 47K mi. This is only the third time I have been to the track with it and I bought it brand new. I don't drive like a nutcase so I really don't know what's causing the car to perform the way it is. Any ideas would be helpful and like I said tim getting a leakdown on thrusday and all of my modifications are located in my sig. Thanks
    -Brett
    06 WRX - Deadbolt Zilla 20g 365AWHP//358AWTQ//TopSpeed
    STi Drivetrain installed by CRE
    Hawk-Eye Alliance #54
    My mod list
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    What elevation were each runs done at?
    What was the weather?
    May 2006
    The elevation is the same. Sea level. It was the same track. And the weather is about 4-5 degrees hotter than the 12.6 run.
    My mod list
    May 2006
    I will post an update to this thread when I get my leakdown test done on thursday.
    My mod list
    May 2006
    Alright, so I got the compression test results back and surprise surprise....everything looks good across the board. All in the mid 140's and and low 150's. So...the mechanic pulls this code P0457. And I immediately start checking all of the hoses for the Gas Evaporation System. When I get to the right rear tire of the car to inspect the gas evap box I see that there is NO sensor on the friggin box....the sensor isnt even plugged in. So since the gas evap box controls vac and pressure of fuel I'm thinking my car has put itself into limp mode. Thoughts?
    My mod list
    May 2006
    Alright, problem was finally figured out by the professionals up at TopSpeed. Cylinder number 3 popped up lean after a couple of Dyno pulls. Scott decided, based on this and other information, that my 800cc PE Inj. for that cylinder was failing. So on his recommendation I bought 4 new 750cc Deatschwerks injs. and got retuned. Car made 371WHP//408WTQ. Picking it up tomorrow. Problem solved.
    My mod list
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Very-Rexy View Post
    Congrats!!
