Results 1 to 5 of 5
This is a discussion on My WRX STI after it has rained. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I am a new member and also a new owner of a wrx sti. I drive a 02 JDM ...
    Sep 2009
    I drive a 02 JDM WRX STI and am loving it!
    However I have one problem. Whenever I park my car outside the garage overnight and it rains, the next day my car does not run properly.
    The severity of what happens varies a bit from time to time, but usually it has a rough inconsistent idle, and weird throttle response. Then whilst driving - if I put it under any load, usually around 4-5000 rpm, all power seems to cut (similar to the feeling of a speed cut). I guess its a boost cut?
    The small mods I have on it are an Apexi Pod filter with the Apexi neck, and a b.o.v.
    Has anyone experienced this?
    Oct 2005
    Late Devonian
    I don't know but would guess at an electrical connection. I'm going to move this to troubleshooting & maybe you can get more help there.
    Welcome to the club!
    Moderator Donkey's Avatar
    Da boonies
    My guess is the filter on the air intake is close to the fender and is getting wet due to water getting in between the hood and fender crack/channel. Happens all the time with SRI's and hard rains.........
    2002 FORESTER S
    1998 FORESTER S
    Nov 2007
    Quote Originally Posted by Rough Chop Tom View Post
    By any chance are you also having voltage issues at the same time. I have a very similar problem. It doesn't matter if it rained or if I just washed the car I get a strange voltage pattern. My symptoms are similar but the one thing I do know if that my odometer backlight will flicker and sometime if I hit the brake the radio will go off.
    I have followed with my ap2 and my voltage ranges from 12.8-15.8 when it is acting up.
    I have a cobb intake so mine should not be associated with a wet filter.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I agree with Ron on this one...
