Results 1 to 2 of 2
This is a discussion on compression loss? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i think i fried my rings! 95 k on the wagon was drivin a little heavy on the gas, got ...
    Registered User WRXwagonMAFIA's Avatar
    Aug 2008
    some old backroad
    compression loss?
    was drivin a little heavy on the gas, got a major boost surge and the car shut off.
    now there is very little power and i believe it is compression loss
    i took my evolll big 16 g off and put stock back on and still 1/4 the boost
    wats goin on??
    04' WRB wagon stage 2
    wagon Mafia #1 Where my wagons at?
    Registered User DorBink's Avatar
    Sep 2009
    Houston, Katy
    Do a compression test. you should be around 150 per each cylinder. If not then your rings are gone, but at least you'll know which one is the problem.
    Good luck.
