It sounds like your clutch is slipping. If so you will need to replace the clutch.
As the clutch fails to clamp during increased torque output from the motor, the revs climb but the car does not accelerate. The boost gauge drops when the clutch is slipping since the effective load on the motor also drops -- the driveline is not linked to the motor when the slip occurs.
LinkBack URL
About LinkBacks
