Results 1 to 9 of 9
This is a discussion on CEL flashing within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My CEL is flashing with a misfire around 4500k. I have a SPT intake and Catless turboback exhaust. Car is ...
    Registered User wrxwagon2's Avatar
    Feb 2009
    allentown,pennsylvania
    CEL flashing
    My CEL is flashing with a misfire around 4500k. I have a SPT intake and Catless turboback exhaust. Car is not driven right now due to the exhaust but Accessport is on its way. But i took the car out to dry it off after a wash and its doing this.
    2004 WRX (currently driving)
    2000 Audi S4 APR tuned (sold)
    2002 WRX wagon ( sold )
    1988 Thunderbird Turbocoupe
    Registered User Steveo47193's Avatar
    Jul 2008
    Sunbury, Pennsylvania, United States
    Is your test mode connectors connected together? Check underneath your steering wheel there should be 2 green connectors. Make sure they are disconnected. I know for my 04 wrx you connect these before you install ur accessport and your check engine light flashes.
    Blobeye Syndicate #43
    Feb 2009
    I never touched those before, i just ordered the accesport and i heard it was unhealthy for my car to drive it with a upgraded DP without a proper tune. I checked the plug gaping and coil packs and put them in and it still does it. Im gonna check the grounds
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by wrxwagon2 View Post
    Not true. Your car is an '02.
    Don't reflash your car until the source of the misfire is found.
    Feb 2009
    whats not true? and im not going too, im gonna pull up the codes and see whats up
    Dec 2003
    Your '02 has no problem running a downpipe without a tune.
    Feb 2009
    well when i was talking to a guy at Rallysportdirect he said its not good to drive it without the proper tune
    Dec 2003
    This applies for +04 models. 02-03 WRXs are fine without tuning, you just won't make as big of gains without it though. You're not misfiring because of the downpipe.
    Feb 2009
    Thats one thing off my shoulders. What could be causing this misfire and the CEL to flash? it only does it underload, like if i romp on it around 4500rpm it misfires bigtime and it doesnt go anywhere
