Boost gauge needle
Results 1 to 11 of 11
This is a discussion on Boost gauge needle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Guys, Where should the needle of the Lamco boost gauge be while the engine is off? Mine sit on -.01...
    Registered User knfevg's Avatar
    May 2009
    Israel
    Boost gauge needle
    Guys,
    Thanks,
    Evgeny
    Subaru Impreza WRX STi ProDrive 2.0 MT6 2003
    Mazda 6 2.0 AT 2008
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by knfevg View Post
    Guys,
    it should be at 0.
    -.01 is pretty damned good. Mine is at .1, and I consider it accurate (it's coming from the MAP sensor that the ECU reads..)
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Dec 2003
    Dallas, TX / Sterling, VA
    it should be at 0.
    The Lamco reads in MPa.
  5. #4
    May 2009
    Israel
    Indeed, it's MPa.
    So, does -.01 is OK?
    BTW, the reading doesnt come from the MAP sensor, but from a hose that is connected to the intake manifold through a T connector
    Thanks,
    Evgeny
    Mazda 6 2.0 AT 2008
  6. #5
    Nov 2006
    Denver Metro Area
    -.01mPa converts to -1.45psi... Not horribly off but enough to raise an eyebrow. If you're at altitude this is a common problem... What's the elevation where you live?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  7. #6
    May 2009
    Israel
    1 mile from a sea shore I would say around 100ft....
    Thanks,
    Evgeny
    Mazda 6 2.0 AT 2008
  8. #7
    Registered User Silversubie05's Avatar
    Aug 2009
    Tri-Cities, WA
    Mine sits at -.01 when its off, I'm about 700 ft above sea level. I was reading that .09 is about 13.5 psi which is supposedly what the wrx wastegate is set to stock. At full boost my car only gets to .08, I was wondering the other day if thats just because my gauge is .01 off or if I'm not actually getting to target boost?
  9. #8
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Silversubie05 View Post
    The needle is probably off. This is the reason why I'm only interested in digital gauges.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  10. #9
    Nov 2006
    Denver Metro Area
    Lol... sounds fun!
    So it's not altitude... have you checked to see how accurate it is against the ECU?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  11. #10
    May 2009
    Israel
    Lol... sounds fun!
    As you can see from a different thread, I'm looking to buy a cable to do some ECU reading.
    Thanks,
    Evgeny
    Mazda 6 2.0 AT 2008
  12. #11
    May 2009
    Israel
    Ok, I removed the gauge from the dash (I have the 3 units installed in the dash bellow the radio) and fixed the needle to be on 0. Tomorrow will see how it works.
    If I decide to get a new set of gauges, what are my options? Any digital ALL-IN-ONE units that works like the PSI3?
    Thanks,
    Evgeny
    Mazda 6 2.0 AT 2008
