Whirlling sound
Results 1 to 7 of 7
This is a discussion on Whirlling sound within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Installed big topmount ic makes high pitch sound.have stock turbo, sounds like intake anyone know what it might be???...
    Sep 2009
    olympia wa
    Question Whirlling sound
    Dec 2003
    Dallas, TX / Sterling, VA
    You have an air leak. Tighten the clamps and your bypass valve bolts.
    Jan 2008
    Nebraska
    It might not be an air leak. Whirring makes me think turbo. I noticed that as well when i switched to a spearco TMIC. It seemed as though i could hear the turbo spooling better. Keep in mind this wasn't a large difference. How loud is the noise? Does it run well? At what RPM and load do you hear this noise?
    As brfatal said, check your clamps and all your flange bolts.
    Sep 2009
    olympia wa
    Ask buddy of mine he said maybe more air movin could cause it but don't I tried tightinghose off turbo put silicon on bypass
    Dec 2003
    Did you use hairspray on the silicon? Did you use a new bypass valve gasket?
    Sep 2009
    olympia wa
    The noise is when I get on the gas I seem to be getting same boost level as before install of tmic
    Sep 2009
    olympia wa
    Didn't use new gasket just silicon
