The AP displays what the cars computer is reading, whether or not it is accurate, who knows. Best thing to do would be to compare it with a quality boost gauge. How did you go about checking for leaks?
This is a discussion on only 6psi!!?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I own a 06 wrx tr and the only mods I have done are cat back exhaust and spt ...
Hi, I own a 06 wrx tr and the only mods I have done are cat back exhaust and spt intake. I bought a used accessport v2 and flash stage 1 91oct. After flashing stage 1, I used the "live data" to check my boost. it's saying only 5.9psi in 4th at WOT!! I then flashed back to stock an checked boost to find nothing has changed(psi). I don't have a boost gauge( besides the AP's live data) so I don't know if I was ever hiting target boost. anyone ever have a similar problem? could the accessport be giving off a false psi reading? I checked for leaks and everything looks good. please help!!
Bugeye Mafia #231 - 2002 WRB - sold Dec 31, 2009
-Stink-Eye Mob-
#173 - 2008 SWP - Returned to TD04 Stage 2 in Jan 2012
Frmr Blobeye Syndicate #173 - 2005 CGM -sold Sept 15, 2008.I miss my STi
Proud owner of 99 RS coupe with EJ205 engine and tranny swap.
I visually checked for cracked or loose lines. I know I need to do a firmware update on the AP, but I don't think that's my problem.(correct me if I'm wrong) also my boost never tapers off either. It stays 5.9psi untill redline. my car doesn't feel any different than it did a year ago. Would only peak boost at 6psi throw some sort of CEL? Also I know prosport is a cheap brand for gauges but I need 1 asap. Are they so bad I shouldn't order it? I also noticed I'm missing my turbo heat shield witch can't be helping my issue![]()
-Stink-Eye Mob-
I checked today and the restrictor pill is in the exact same spot as shown in the diagram. Anything else I should check before making an expensive call to the dealer? (its going to be funny explaining to them i suspect my car of underboosting like a MoFo without a boost gauge)I updated the firmwear on the AP and now it said my peak boost was 6.5 How sad is that....![]()
Try adjusting your wastegate actuator arm. When i first got my 02 it didn't have any pull but i could hear the turbo spool. Once i got my AP it read my peak boost at 9.5psi ish. I adjusted the wastegate are to make it shorter by about 2 turns and now i am hitting 14.5-15 psi and the car is pulling like it should.
This is link i used when i did mine.
Wastegate actuator arm adjustment - NASIOC
-Stink-Eye Mob-
I really didn't want to go messing with the wastegate if I didn't have to. So I called my dealer and had them check it out. they had my car all day and they are claiming everything is normal. The tech told me if I was underboosting it would throw a CEL. Does anyone know if that's true? Also can my spt intake cause the AP to be this far off with my boost? I have a subaru tech telling me my car is fine, and an accessport telling me I'm only making 6psi. Who or what should I believe?
I have a prosport 52mm peak/hold boost gauge and i love it. i just ordered there oil temp and oil press. gauges too then the exh temp when i put my TBE on. for the price u cant beat them. i ordered from street unit, cheapest around and great shipping. plus they give you all sorts of discounts for some reason. like returning customer discounts.
Well I solved my underboosting problem, it was that god damn restrictor pill the whole time. The first time I checked for it I located it, but didn't realize it was in the wrong line. Now when I put it in the correct line I overboost to 15psi.(stock map) havn't tried stage1. I'm having DSG (dent sport garage) fix her once and for all. I heard they do awsome work, and are located fairly close to me. (mass)
wow id say u r pullin some boost. my 04 sti is stock other than a drop in KnN. n i only hit 14.8 14.9 lbs
