Shot Turbo? or something else? - Page 2
Results 16 to 30 of 31
This is a discussion on Shot Turbo? or something else? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Those look like the rear pinion bearings in the pic. But yes the pinion bearing is kind of in the ...
    Aug 2008
    Kennett Square, Pennsylvania
    Those look like the rear pinion bearings in the pic. But yes the pinion bearing is kind of in the tailhousing of the trans by the transfer gear, there is also a pinion bearing in the trans iteself.. To be honest with you I have never seen a Subaru have a defective rear pinion bearing, however Its not that uncommon the one in the trans goes over time.. Did rallispec do anything with the Viscous coupler or transfer gear/bearings when they did the trans? OH ok the airport is about 40 minutes from me..
    Registered User AgentH's Avatar
    Feb 2005
    Philadelphia Area
    I'm not sure... I'll give them a call.
    Hopefully I'll find something when I jack it up again and start shaking things around under the car.
    ... back when I replaced my trans, I put both the grp n engine and trans mounts in. Shortly after the installation, I noticed my Engine mount bolts were gone Hopefully nothing retarded like that has happened and caused excessive wear and tear on any of my drivetrain components.
    2nd WRX...
    More than meets the eye.
    May 2005
    Phillytown, PA
    Neil, any vibrations you feel?
  6. #19
    Aug 2008
    I would def. be sending the trans back to rallispec....I have a gut feeling the case halves will have to be split again or the tailhousing/transfer case will have to come off..
  7. #20
    Feb 2005
    Philadelphia Area
    I feel the noise in the shifter when I'm cruising in gear. :-/
    barring my last comment, I dunno. Stuck it up on Jacks just now and poked around under there for a while and Nothing struck me as being abnormal. No fluid is leaking out of any of the outputs of the trans. When I push, pull, and tug on the rear drive shaft (propeller shaft? -part 1 in that drawing), there's hardly any movement. Further down the drive shaft, there's a rubber bearing assembly (center bearing? -part 2 in that drawing) that allows the drive shaft to rotate in and has some compliance. I think if this was going bad, I'd see all sorts of grease leaking out of it. It allows flex, but it feels solid axially. That attaches to the rear diff and there's no slop there either.
    The only thing I saw was my dr side engine mount has a wacked out washer and lock washer that I need to replace at some point.
    Also, do you know if when you grab the DOJ on your front halfshafts if you can push up and down and get about 1/8 - 1/4" play out of it? What about if you give them a plunging motion? I get the same exact motion out of both sides, so I don't think that is my problem. The motion is in the trans, not the DOJ.
    I'll give Rallispec a call tomorrow and get their opinion.
    JR or Evoeater, do you guys know any local to us subaru dealer mechanics that aren't jerkoffs? I'm going to throw in the towel.
    2nd WRX...
  8. #21
    Aug 2008
    I don't consider myself a jerkoff.......Let us know what you find out from rallispec as far as warranty and such goes also...I would def be demanding rallispec to at least inspect the unit before you go paying someone for diag. noise in the shifter huh..another hint which points to a pinion bearing or another bearing in the trans.. Also It is somewhat normal to get that amount of play out of the front axles on pretty much any Subaru..especially with that amount of mileage, my Legacy has over 200k and I have a tad of play in mine also...
  9. #22
    Feb 2005
    Philadelphia Area
    I didn't mean to insult you or anyone by that comment, but I'm sure even you know what I mean. The auto industry has a TON of floating around and I've been given the run around by plenty of know it all mechanics. ... which happens to be one of the reasons why I like doing everything within my capability for my car on my own.
    Anywho, I'm going to try and escape the clutches of my job for a little bit and get over to Jersey to have them give me their opinion on what the problem is.
    The trans is Rebuilt, but according to Rallispec, when rebuilding a trans, the bearings that seem fine are kept to keep costs down. Now if I were to take my axles off, I could push the splined stubs that the axles attach to in and out. I'm pretty sure I could also rock them up, down, and side to side as well.
    As far as the Axle's go, I would think that they would make more or less noise when I turned hard or got the suspension to work since they would be loaded differently than when driven in a straight line.
    2nd WRX...
  10. #23
    Sep 2009
    i think the turbo is shot
  11. #24
    May 2005
    Phillytown, PA
    Quote Originally Posted by AgentH View Post
    This statement would lead me to think that something in the trans isn't correct or possibly your U-Joints in the drive shaft might be going bad.
    From everything I've heard Rallispec does good work, so I'd think that the transmission should be right, but mistakes can and do happen.
    I'd like to take a look at the car and see if we can shed some light on what might be the culprit.
  12. #25
    Aug 2008
    No No man..lol...Just joshing around..lol... ...Like you mentioned my first stop would be back to rallispec see what they think than go from there...
  13. #26
    Feb 2005
    Philadelphia Area
    Oh
    Tomorrow evening? I didn't want to bug you too much since I know you have a ton of stuff going down which includes your own car!...
    I'm gonna hit up Rallispec tomorrow for sure. Man... the last thing I want to do is take the trans out again!
    I checked it out and there was No play on it what so ever. I think it's solid.
    2nd WRX...
  14. #27
    Feb 2005
    Philadelphia Area
    So.... I went to Rallispec on Friday. Jordi took it out and definitely felt as though it's coming from the trans. Per his request, I then did something I should have done the first time I put it on jack stands. With a friend in cabin, the car was put into drive while I crawled under the car and listened to parts of my trans using a mechanics stethoscope. Surely enough there was a wobbling sound coming from my trans every revolution. The sound was a lot louder towards the rear of the car, which is good news. Jordi said he can crack the case of the trans and replace certain things with it still in the car. Actually, that's really good news. The bad news is I will have to pay for labor and parts on a 6 month newly built trans. But, so long as the prob is fixed, I'll be greatly relieved!
    2nd WRX...
  15. #28
    Aug 2008
    There is no way you can split the case halves of the trans with the trans in the car...You can however remove the tailhousing and the transfer case with the trans in the car..Hopefully its not a bearing on the mainshaft or pinion shaft...Let us know how it turns out...
  16. #29
    Feb 2005
    Philadelphia Area
    haha, good point! Poor use of terminology... yea, that's it.
    ...Will do!
    2nd WRX...
  17. #30
    May 2005
    Phillytown, PA
    What? Why?
