ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 09-11-2009, 07:54 PM   #1 (permalink)
Gas Pedal Problem
Hi there. I have just installed new headlights in my 08 Subaru wrx. In order to do so, I had to remove the battery and the K&n Intake. After I was finished, and hooked everything back up, I notice a significant change in throttle response. If i just touch the gas, it doesn't do anything. Before, when I touched the gas pedal slightly, the engine would rev. What happened?
p.s Are 80 watt bulbs safe...?
Regards,
Anthony
Ant428 is offline   Reply With Quote
Old 09-11-2009, 08:13 PM   #2 (permalink)
wrxnews's Avatar
Send a message via Yahoo to wrxnews
If i'm not mistaken your ECU has to "relearn" how you drive.
Do a search because it's been covered here on the forum before...it should turn up.
Off the top of my head you can speed that process up if thats the case by gently braking while in 3rd gear...but alas it escapes me.
Unabombers Manifesto
Unabomber's Manifesto - NASIOC
__________________
<-----#1 Fanboi
Stink-Eye-Mob #19
ECU cracked by RomRaider
wrxnews is offline   Reply With Quote
Old 09-11-2009, 08:51 PM   #3 (permalink)
The Mushroom Moderator
mycologist's Avatar
I would look at the way the intake is put back together and check/clean the MAF connection.
The ECU shouldn't reset unless you drain the residual power and relearning isn't that severe.
__________________
mycologist is offline   Reply With Quote
Old 09-12-2009, 03:58 PM   #4 (permalink)
EvoEatr's Avatar
As mentioned the ECU has to relearn the way your drive. The biggest problem with this is throttle position because all the newer Subarus are throttle by-wire. Sometimes on higher mileage Subarus with throttle by wire you have to pull out the air intake and clean the carbon out of the throttle body fore the ECU is initially getting the wrong reading if there is any carbon in there ( sticking the throttle plate open a tad)...Give it a few days It should be back to normal..or If you have the time I would pull off the intake and clean the throttle plate/body and after doing that let the car idle for a few min...
EvoEatr is offline   Reply With Quote
Old 10-25-2009, 03:37 PM   #5 (permalink)
'02 wrx's Avatar
Quote:
Just curious, how new are you talking when you say "newer subarus"? i have a 2002 wrx and i think its starting to do what Ant428 wrx is doing but everything is stock. to be more specific, at random times when i shift, let the clutch out, and hit the gas, there is no throttle response for X amount of seconds and then the the throttle comes back and the car jumps forward and normal driving resumes. i'm a noobie and this is freakin me out. thanks in advance
'02 wrx is offline   Reply With Quote
Old 10-25-2009, 04:28 PM   #6 (permalink)
EvoEatr's Avatar
Quote:
Your 02 WRX has a throttle cable...I would make sure the throttle isn't sticking and I would also make sure the throttle body isn't carboned up fore I've seen a carboned up TB cause problems like your describing...Also make sure the cable is free and isn't getting hung up on anything...
Old 10-25-2009, 05:12 PM   #7 (permalink)
'02 wrx's Avatar
thanks a bunch. sorry but i have one more question regarding the throttle body. this cleaning process i imagine would most likely mean taking the tb off. is that something i can do at home or is it best to take it to a dealer/shop? thanks again
Old 10-26-2009, 02:31 AM   #8 (permalink)
EvoEatr's Avatar
no prob. man.. this is a shot from the hip from the info. youve given me..lol...no you can leave the throttle body on..however you will have to remove the intercooler which is pretty easy..two hose clamps a couple vacuum lines and 2 bolts...you should be able to move the throttle by hand and kind of feel whether its sticking or not...anyways maybe here will be of some assistance.. Impreza Manuals | ken-gilbert.com
Old 10-26-2009, 08:22 AM   #9 (permalink)
Reincarnated Stalin of WRX tuning
Donkey's Avatar
Quote:
Regards,
Anthony
80 watt bulbs are illegal and very unsafe for the other drivers on the road and your light housings due to the amount of heat they would put off.
__________________
My Mods My Pics
Donkey is offline   Reply With Quote
Old 10-26-2009, 04:14 PM   #10 (permalink)
'02 wrx's Avatar
thanks again EvoEatr
Old 10-26-2009, 04:39 PM   #11 (permalink)
jeremy96gase's Avatar
Quote:
+1
This thread is for a bugeye, but the materials used for the headlight and harness are the same as your car.
Headlights burning out - WRXFanatics.com WRX Forums
55/65 watt bulbs are what you should be using.
jeremy96gase is offline   Reply With Quote
Old 10-26-2009, 05:53 PM   #12 (permalink)
EvoEatr's Avatar
no prob man..let me know how it turns out...
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
hesitation when pressing the gas pedal borinquenwrx General Maintenance, Troubleshooting & Accidents. 6 11-11-2007 07:51 PM
Ran out of gas - still gas in the tank... MooseMan General Maintenance, Troubleshooting & Accidents. 17 06-28-2007 04:42 PM
CEL Codes for WRX and STi YBNormal07 Maintenance, service, and repair 2 06-12-2007 01:20 PM
Problem #2: Hesitation between 3k - 5k rpm, flashing CEL Zapix Engine Modifications 20 02-10-2004 11:10 AM
Weird Vibrating in gas pedal.. wasnt there before, that i can recall? MaK10 Engine Modifications 0 06-05-2003 03:48 PM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
