Cam Gear problem
Results 1 to 10 of 10
This is a discussion on Cam Gear problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Alright so I've recently come upon a problem, my L-EX cam gear has broken along with the timing belt. I ...
    Registered User GuamKid's Avatar
    Sep 2009
    Washington
    Cam Gear problem
    Alright so I've recently come upon a problem, my L-EX cam gear has broken along with the timing belt. I was wondering what the consequences of this could be on my engine, and if it's possible to use the 2.5L Sti cams on an EJ20. Any input is appreciated!
    Jul 2004
    Seattle, WA
    Take a look at some of the other broken timing belt threads.
    ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums - Search Results
    The EJ series engines are interference style. At minimum you will need to pull the heads and replace some valves.
    Sep 2009
    Washington
    Quote Originally Posted by jeremy96gase View Post
    Ahhh man, well thanks anyway.
    Aug 2008
    Kennett Square, Pennsylvania
    There are a few rare cases I've seen where DOHC EJ's have jumped time and no valves got bent...Its like a once in a blue moon thing but you don't want to go pulling the thing apart if you dont know for a fact anything else is wrong. I would be installing a new LH exhaust cam sprocket,tensioner, and t-belt and see if the thing starts first...
    Sep 2009
    Washington
    I was gonna do that but if the internals "were" damaged wouldn't that only further damage it?
    Aug 2008
    You will know immediately when you start it if the valves are bent because you will def hear/feel it, It will idle like hell. If things are damaged things are damaged, the thing will have to come apart. I will put it this way if the valves are bent the valves are bent either way they will have to be replaced..All I know is this is what I would do before I just pulled the heads off or the engine out...
    Sep 2009
    Washington
    Alright, I'll definantely give that a try first.. Thankfully I've only gotten as far as removing the wiring and downpipe.
    Aug 2008
    Quote Originally Posted by GuamKid View Post
    you can keep the downpipe off if you like..lol...if it does start it will sound cool...I cant stress this enough though..make sure the timing marks are lined up.. check this out..i used this when i did my first EJ DOHC t-belt years ago..... http://endwrench.com/images/pdfs/2.5Timing.pdf
    like i mentioned you should know immediately if the valves are bent...klack klack klack sound kind of..
    Dec 2003
    Dallas, TX / Sterling, VA
    Already? Yikes.
    Sep 2009
    Washington
    Quote Originally Posted by brfatal View Post
    Already? Yikes.
    Yup! But its not the Subie's fault, it's a drunk driver and our head on collision.
