Stay away from all additives - they are not needed. 5W-30 is recommended by Subaru, not just the dealers. It is all I have ever used.
Read on: Motor oil - Wikipedia, the free encyclopedia
This is a discussion on another oil question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Sorry this is kinda long. I have an 07 impreza wrx with 36000 miles. I have been reading some of ...
Sorry this is kinda long. I have an 07 impreza wrx with 36000 miles. I have been reading some of the threads on oil. I have seen not to use 5w 30 and also have seen that 5w 30 is noisy in our motors. Which i am getting some noise out of my motor. I am sure there is 5w 30 in the motor cause thats what the dealer put in it when i bought it. Also according to those motor oil bibles i have been reading. If i am understanding some of that stuff right. The number before the w stands for cold viscocity and the number after stands for hot viscocity.
To try to get rid of the noise and for better protection would it be better to use 10w 40 instead of the 10w 30 because there is only the cold viscocity number change.
Also anyone ever use or heard anything good or bad about that lucas oil additive good idea or bad idea to use
Thanks in advance.
Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
New Member Hangout / Off Topic / Tri-State
Mods & Pics
thanks i really wasnt planning on using the additive. just heard some people that have muscle cars talking about it. doesnt subaru recommend the 5w30 oil for fuel economy.
I have looked at the manual. Looks like in my climate i can use any of the viscosity. The 10w30 and 10w40 i can use it to alittle blow 0 degress and above 100 degress. I should be fine with any kind of oil.Thats why i am asking if 10w40 would be better to use than 10w30 thanks for your help.
That depends on what "better" means to you. If by better you mean "produces less wear in the engine" then the only way to do is to either generate your own used oil analysis data or look at that data generated by others from the same oils in the same motor that you discuss. If by better you mean "makes the motor consume less oil" then that you can figure out empirically.
These oil threads have got to end. All you have to do is read the owners manual or the factory repair manuals. Most of the people spouting off 75% of this info have no idea what they are talking about anyways(the above is the other 25% that post actual intelligent and spot on info which is a miracle by most forums).
