Results 1 to 9 of 9
This is a discussion on CEL Code within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm poping a P0102 code. Basically this means that there is a problem with the Mass Air Flow (MAF) sensor ...
    Jul 2009
    Lafayette, IN
    CEL Code
    Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. A more technical description would be that the MAF circuit had lower than expected voltage (air flow).
    When I clear the code, it shuts down the engine. Restart the engine and its back. I checked all the wires, they all look good, the MAF is very clean, looks almost new.
    Any suggestions to try before I start spending money?
    Thanks
    Moderator Donkey's Avatar
    Da boonies
    What year car? List all your mods. If you can tell me "the MAF is clean" then you probably really don't what exactly to look at. Search for the tutorial on "MAF cleaning" and try cleaning the MAF with the appropriate cleaner then reset the ECU.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2009
    Lafayette, IN
    '02 WRX. ....mods related to this would be:
    Perrin up-pipe
    Invidia bellmouth down
    Injen intake
    16G turbo
    larger IC
    The little blub on the MAF is amber and the contacts are clean, no sute. I pulled the connecter apart, the brass contacts are clean, etc.
    Registered User CactusAndy's Avatar
    Aug 2009
    Phoenix, Arizona
    Did you recently just add the intake or change it from a different one? In all instances its a good idea to buy the $4 MAF cleaner just to make sure.
    Jul 2009
    Lafayette, IN
    CAI was one when i bought it. CEL light came on shortly after I bought it, but I havent messed around with it until now.
    Da boonies
    When did the problem start? Was it after the installation of the intake? It almost impossible to visibly tell if the MAF is contaminated. The amber bulb is the IAT sensor and oil from aftermarket filters will easily contaminate the MAF sensor. The actual MAF sensor is the tiny wires down in the tube.
    2002 FORESTER S
    1998 FORESTER S
    Aug 2009
    Phoenix, Arizona
    how recently did you buy the car? I'm wondering if the previous owner had some sort of tuning device (UTEC, Cobb) and took it out before he sold it...just a thought
    Jan 2005
    Canada B.C.
    Did you take it out? Did you maybe put it in backwards?
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Jul 2009
    Lafayette, IN
    Quote Originally Posted by CactusAndy View Post
    Ya thats most likely the solution. I bought it a year ago. When I bought it, I found a bunch of stuff he's taken out before he sold it.
    My wife drove it right after we bought it, and I just recently started to drive it as my main car in the past few weeks, so I'm finding and trying to fix all these little things.
    As far as being put in backwards, I'm not sure. Its in the same way its always been in. The plug of the sensor is towards the front of the car.
