Timing belt replacement
Results 1 to 15 of 16
This is a discussion on Timing belt replacement within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; anyone know how to line everything up so i can put the new timing belt on. i wrecked it and ...
    Registered User roger lux's Avatar
    Sep 2008
    chattanooga, tennessee
    anyone know how to line everything up so i can put the new timing belt on. i wrecked it and she jumped time. i have nothing to go on because it's already out of time.....
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by roger lux View Post
    Hopefully no valves are bent...take a look here... the procedure is pretty much the same for all current/new gen. DOHC Subies.. http://endwrench.com/images/pdfs/2.5Timing.pdf
    Apr 2004
    Southeastern PA
    Curious - how many miles / years?
    Mods & Pics
    Sep 2008
    100,000 miles and it's an 04..ty guys
    Flirty User That's Younger Than the Chunks of Corn in Brian's Crap
    WRXie's Avatar
    Mar 2009
    Down South
    My god. What did you do? (Assuming that is your car in the picture.)
    2002 WRX Yellow Blaze
    Bugeye Mafia #216
    High Mileage Club
    Sep 2008
    too fast for conditions and failure to maintain lane. this is the stage i'm at now. this took me a year and a half. i still need a right rear spindle and of course the timing set.
    Sep 2008
    an update here and a related question.......
    first off i have fixed everything except putting the fans back on and replacing the timing belt covers. will NOT start since it turned cold. it idled super-duper rough this summer but i was putting an axle and hub on the back. i wasn't worried about it running if it wouldn't roll. anyway i got a used one that had a busted anti-lock brake sys. so i mated the two it took me over a month to find it. now it's cold and won't start. it wants to start SoOoOoo bad. but won't.
    what think ye?....i have a timing belt and i was wondering how much torque it would take to get that nut off the harmonic balancer looking thing. p.o.s. dealership won't come off the "special" wrench only they have.
    Aug 2008
    The crank bolt is a 22mm pop a huge breaker bar and socket on the bolt......This might seem like an unorthadox method however I use it only when I have to...because not properly secured it can be dangerous....you position the breaker bar on top of the side frame rail and "bump" the engine just enough to break the bolt loose...( make sure you have the breaker bar oriented properly....i take no responsibility if anything breaks or you hurt yourself...lol)...Like said Ive used this method before and it does work, however only when I have to now that I work for Subaru....No start when cold im thinking a shot from the hip perhaps a CTS...This is by going that the car has a fully charged battery, healthy starting system and the timing belt is properly installed...
    Sep 2008
    cts?
    Aug 2008
    cts?
    Coolant Temp. Sensor...thats a shot from the hip though..
    Sep 2008
    ok guys thanx for everything! i got everything going. it was the timing belt. one side jumped entirely out of time but each set of cams stayed in-sync w/ themselves so (thank God) no damage to the valves. Now...I'm throwing codes. if any one has anything that can help me pass Tennessee emissions please let me know. they won't o.k. me with a check engine light.
    Aug 2008
    What are the codes your throwing?
    Sep 2008
    all misfires and a co2. i put injector cleaner in it because it sat for a yr. the light went off last night after i filled up w/ premium and drove for a while. (fingers crossed)
    May 2007
    behind the wheel
    have you cleared the codes since trying to start it out of time?
    Start there.
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
    Sep 2008
    by unhooking the battery?....
