confused on oil
Results 1 to 9 of 9
This is a discussion on confused on oil within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey everyone, i have been going throught treads and i keep reading different oil stories. i have been using mobil ...
    Registered User jdmsti05's Avatar
    Mar 2009
    ca, mira loma
    confused on oil
    hey everyone, i have been going throught treads and i keep reading different oil stories. i have been using mobil 1 10-40 i use it cause i live in ca and ita been in the hundreds every day. should i go to 5-30 or 10-30 or stay with 10-40 also i know everyone has there own oil but what do u chose castrol synthetic or mobil 1. oh and the car has 85000 miles so its not a new engine thats also why i went to a thicker grade, the car is also a stage two and tbe no other mods.
    What is your usual oil change interval? What consumption, if any, do you see during that interval?
    Mar 2009
    ca, mira loma
    i change it like ever 2500 or 3000 just cause iam picky on it aand no it doesnt burn or leak
    OK that's a very frequent change interval. I assume from your name that you have the 2.5L STi. See the oil TSB and select an oil that fits the criteria stated (as revised) by Subaru:
    Oil TSB for 2006+ Subarus
    Since you have an 05, you need ILSAC: GF-3 - or - API: SL or better oil. If M1 10W-40 meets those criteria you can comfortably use it despite Subaru's recommendation for a 5W-30. I am assuming you are out of warranty. If you don't have a bottle to check the specs go to their website, Mobil1.com, and use the drop down menu.
    Mar 2009
    ca, mira loma
    i just checked it and it meets API SL/CF. does this thicker oil cause hp loss or does it not matter sice its not that big of a difference what do u use and yeah its a 2.5 l sti with no warranty.
    Quote Originally Posted by jdmsti05 View Post
    Since it's SL you should be fine. Note that the complete spec is SL "Energy Conserving" but I do not think any 40 oil will meet that -- I may be mistaken; in any case the manufacturer does, if memory serves, allow for a 10W-40 in warm climates (check your owner's manual).
    It does not matter.
    I use M1 5W-40 "Turbodiesel" or M1 0W-40 "European Formula" depending on which is cheapest or simply which is available. Others use other oils. The key is to follow the maker's specifications and if there is any doubt about the oil's performance or how suitable the oil is for your circumstances, do a used oil analysis by sending a sample off to a lab. Blackstone Labs is one such lab; there are a few others too I think.
    Mar 2009
    ca, mira loma
    cool thanks for the help
    Sep 2009
    additional info... i'l stick to that.
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
