Overfilled Oil?
Results 1 to 11 of 11
This is a discussion on Overfilled Oil? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; about a week ago i did my first oil change on my 02 wrx, drained the oil, pulled the filter ...
    Aug 2009
    Upstate NY
    Overfilled Oil?
    about a week ago i did my first oil change on my 02 wrx, drained the oil, pulled the filter off... come to find out my kid musta thrown my new filter out the window while we where driving. and it was late so i left the drain plug out and the car on stands overnight.
    next day toss the filter and oil in, car took all 5qts and seemed to be about right on the full dot (figured it took extra because the 12hr drain period it had).
    well today i was bored so i decided to install a new pcv valve and fuel filter. started the car up for about 1min to verify there was no leaks then shut the car off. let it sit 5-10 min and checked the oil and it was below the low dot.
    i put about a qt or so in, and it was again on the full dot, went for a 5min drive, got it to normal temps, let it sit 10min and checked again and its way over full now, almost upto the halfmoon cut on the dipstick (right before it twists).
    just to be sure... let the car sit overnight, check again while cold and if its overfull pump some out? or do i need to get it to op temps and check again?
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Been there done that.... I'm sure many have.
    Our cars are cruddy for checking oil levels. I HAVE to chk mine in the AM after sitting all night. I would say you are overfilled. Let it sit overnight and chk it in the AM. If it isn't registering.... there may be another issue.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Fill it to the F line when cold, then it should be over the mark when checking it after the engine is warm. Also make sure it is on level ground.
    The capacity for my car is 4.2qts, so I drain and fill to that. I've never put the whole 5 qts in.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Registered User Acrdys's Avatar
    Jun 2007
    Lemore
    yeah I don't trust my little stick thing.
    I put exactly 4.5 quarts in. Check that stick, and if it's in the dot i call it a day.
    After that I just make sure I have oil pressure. If I don't something's wrong :P
    Hawk-Eye Alliance#8089
    MODS LIST
    Registered User CJ05's Avatar
    Apr 2008
    North Juarez Mexico (aka El Paso TX)
    Happened to me before also. Checked my oil and it was below the L. Put about a quart in and it was right in the middle, figured i was good. Drove it around some more, checked it again the next day and it was well above the F. Doesn't make sense to me either.
    Bugeye Mafia #231 - 2002 WRB - sold Dec 31, 2009
    -Stink-Eye Mob-#173 - 2008 SWP - Returned to TD04 Stage 2 in Jan 2012
    Frmr Blobeye Syndicate #173 - 2005 CGM -sold Sept 15, 2008. I miss my STi
    Proud owner of 99 RS coupe with EJ205 engine and tranny swap.
    Aug 2009
    Canada/Ethiopia/Madagascar
    FWIW, my '06 has a notch a cm or two above the full mark, the manual states that when the oil is checked hot it is fine for the oil level to be up to the notch because of thermal expansion.
    ...Rob.
    Aug 2009
    Upstate NY
    i checked again today while the car was cold, cant really tell, wrx dip sticks suck.
    one side its full upto the bend with oil all over the place, the back side its on the cold full dot.
    i might just drain the hole thing and refill. would cost the same as a pump to pump the oil out.
    Oct 2005
    Late Devonian
    Quote Originally Posted by Mekks View Post
    You can drain some through the drain hole without letting it all out.
    Capacity is 4.8 qts. on mine anyway, not 4.2?
    I think the extra quart is overfull - the reading that showed low was probably just the screwy dipstick factor.
    Dec 2006
    Philly/DE area
    I have the 2.5l so maybe it's different. The Service Manual states for an 06-07:
    2.5L Turbo
    Total Capacity (at overhaul) - 5.3 US Qt
    Filling amount of engine oil (at filter replacement) - 4.5 US Qt
    Filling amount of engine oil (w/o filter replacement) - 4.2 US Qt
    I always prefill the filter, so I go with the 4.2Qt amount.
    Not sure with the 2.0L engine.
    Dec 2006
    Philly/DE area
    Just don't loose your grip on the drainplug, like I did one time. With my head under the hole. And no drain pan underneath (I had a small cup to just catch a dribble). Oh and no drop cloth on my new concrete floor.
    Jul 2008
    San Antonio
    I say it's all good.
    N-swinger
    2000 Escort
