just got an 02 wrx
Page 1 of 3 123 LastLast
Results 1 to 15 of 44
This is a discussion on just got an 02 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just bought an 02 wrx. It has 101,000 miles on it. I was just wondering if I could get ...
    Registered User RugbyJKC10's Avatar
    Aug 2009
    Ft Collins, Co
    just got an 02 wrx
    I just bought an 02 wrx. It has 101,000 miles on it. I was just wondering if I could get some tips and pointers on how to maintain the car? This is my first turbo so I have no clue as to what Im doing.
    Go to a dealer, have them check your VIN and tell you if all the recall and TSB work has been done.
    Follow the maintenance schedule in the owner's manual to the letter, and use authentic Subaru parts as much as possible. Use the correct fluids as specified in the manual.
    Maintenance is generally no different than any other gasoline-motored car. Just follow Subaru's routines in the manual. Dealer add-ons and "recommended" items are irrelevant; only what the manufacturer wrote or ammended matters.
    Aug 2009
    Ft Collins, Co
    alright thanks. What might be causing shaking of the steering wheel going around corners?
    Loose lug nuts, steering component, or suspension; you'd have to look closely at the front end.
    Aug 2009
    Ft Collins, Co
    so how long should I let the engine run for to let the turbo cool down because I live in the mountains and most of my driving is a little harder on the car? I have a lot of questions about the car
    Quote Originally Posted by RugbyJKC10 View Post
    I'm betting most of them are answered in the manual. That one is, for example. You do not need to take special considerations for the turbo itself on shutdown; treat the motor as you would any other car. To you this probably means if you are used to letting other cars cool down under the same circumstances, do so with this one; otherwise just drive conservatively for a block or two before shutting down to let the car cool as you go. The manual does warn against driving hard when the car is cold, though.
    Aug 2009
    Ft Collins, Co
    alright thanks
    Aug 2009
    Ft Collins, Co
    just curious... what can i do to get better gas mileage? I dont accelerate very hard that often but i still only get around 18 mpg on the highway
    That's really quite low. I've managed 28 mpg and 24+ is routine on open roads. First, as above make sure the car is up to date on maintenance. Make sure you have correct pressures on each tire, and shift as early as possible without lugging the motor. If things do not improve dramatically it's either you or the car.
    Aug 2009
    Ft Collins, Co
    i have an automatic but i try to accelerate as easy as possible unless im merging and need to get over.
    Ah, I see; I have a 5spd. I don't know how the automatics behave so disregard my previous statements. Maybe an auto owner will post.
    Aug 2009
    Ft Collins, Co
    i just checked my coolant and its pretty low... im not quite sure if the place i bought it from filled it or not but if they did
    Aug 2009
    Ft Collins, Co
    what should i do if im seeing blue smoke coming out of the area to the left of the engine? and also i found a pool of gas ontop of the engine what could be causing these problems?
    If you actually found fuel on top of the motor, do not drive the car. Have it flatbedded, NEVER towed, ALWAYS flatbedded, to a mechanic for service. The smoke is likely oil burning off, suspect an oil leak either on the rocker cover onto hot exhaust or from either end of the oil feed line for the turbo. This leak is the least of your worries though. Fix the fuel problem.
    Aug 2009
    Ft Collins, Co
    I was planning on taking my car to the tech in my town on tuesday. What is the most likely cause for the fuel leak and how much will it cost to fix?
