Results 16 to 30 of 44
This is a discussion on just got an 02 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; also the place I bought my car from said that they spilled oil in that area is most likely the ...
    Registered User RugbyJKC10's Avatar
    Aug 2009
    Ft Collins, Co
    also the place I bought my car from said that they spilled oil in that area is most likely the cause for the smoke? and how long would it take for the oil to burn off?
  2. #17
    Registered User Undercover STI's Avatar
    Jul 2006
    Arizona
    i had that fuel problem on mine, its most likely the fuel rail or the fuel lines connecting both sides. Either way the intake manifold has to come off to repair. That could also explain your mileage concern. As for the low coolant mention it to the mechanic fixing the fuel problem and they can pressure check the coolant system for leaks. If it had its routine service at 90k the coolant should have been flushed and possibly not filled properly which is likely cause filling the coolant on these cars is different from a normal car. We have the over flow tank and the upper container with the pressure cap on it. They have to be running with the throttle cracked slightly to fill them completely.
    12.7 1/4 mile w/ intercooler sprayer
  3. #18
    Aug 2009
    Ft Collins, Co
    okay thanks for the insight! how long and how much would a repair like this cost normally?
  4. #19
    Jul 2006
    Arizona
    expect around 300 to 400 bucks for repair and if they have the parts it should take a day or 2 to repair. As for the oil burn off it can take a few days depending on how much they spilled. I did the repair my self and put an APS fuel rail system.
  5. #20
    Aug 2009
    Ft Collins, Co
    alright thanks a bunch... will this help my gas mileage a lot?
  6. #21
    Jul 2006
    Arizona
    these things run alot of fuel pressure and if your dumping it onto the engine you run a fire hazard and are wasting fuel.. It should go up a lot. Before i modded the hell out of mine i got around 28mpg highway with a 5 spd. Autos i think got around 26mpg highway. If it doesnt go up that is something to have looked at but wait til your fuel leak is repaired. I make around 400hp with mine and get 18 mpg highway now
  7. #22
    Aug 2009
    Ft Collins, Co
    alright thanks for everything
  8. #23
    Aug 2009
    Ft Collins, Co
    So i took my car into the Subaru tech in my town. The leak that im seeing is actually power steering fluid not gas. I also have a ripped axle boot. Those are the smells Im experiencing i guess. He also said that for my gas mileage problem i should use something called 44k.
  9. #24
    Jul 2006
    Arizona
    What is 44K? And what kinda mileage did he say you should expect? You said you saw fuel on top of the motor, which side and where?
  10. #25
    Aug 2009
    Ft Collins, Co
    i guess it wasnt fuel after all... i showed him the leak and he said it was power steering... 44k is a fluid that you put in your gas tank and it pretty much cleans your fuel line... the guy said i should be getting way better than 18 mpg he said that even for living in the mountains i shouldnt be getting that low
  11. #26
    Jul 2006
    Arizona
    oh ok, sounds good than. Did that fix the front end problem you mentioned?
  12. #27
    Aug 2009
    Ft Collins, Co
    yeah that explains the front end problem i was having... im taking my car in on friday. Hopefully it wont take longer than a day or 2.
  13. #28
    Aug 2009
    Ft Collins, Co
    well i took my car in today. They put in a new front right axle, flushed my coolant, stopped my power steering leak and a bunch of other things all in a couple hours but they said that i need to change a timing belt soon and i need to get a tune up... im a noob at this whole car thing so how many timing belts does my car actually have? just one right?
  14. #29
    Jul 2006
    Arizona
    pretty sure just one, around 100k miles is a good time to look into it. Also putting some new spark plugs and coil boots is a good idea if you don't know if they have been done. New plugs may help your mileage out. Put in what they recommend stay way from multi-pronged plugs though i have heard force inducted cars don't like them.
  15. #30
    Aug 2009
    Ft Collins, Co
    also whenever im warming my car up and i have the a/c or the heat going i get this strange smell inside my car... what might this be?
