Results 1 to 6 of 6
This is a discussion on Oil on the turbine blades? :( within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just bought a used TD04 and got to taking a look at it, and it has an oil residue ...
    Jan 2008
    Nebraska
    I just bought a used TD04 and got to taking a look at it, and it has an oil residue on the turbine blades and housing. I can't imagine this is a good thing.
    The TD04 i just pulled off my car (100k miles) has no oil whatsoever on any part of the turbine housing/wheel. Bone dry. Of coursie it has the standard black carbon deposits, but other than that, dry.
    I was going to replace my high mileage TD04 with this newer one (30k miles) since mine was starting to eat coolant a little and whine a lot. What do you guys think? Are there any non-dead turbo reasons why there might be so much oil residue on the blades and housing?
    Jul 2008
    San Antonio
    A little from blow-by..... Snap a pic.
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Aug 2008
    Kennett Square, Pennsylvania
    +1^
    Oct 2005
    Late Devonian
    Or maybe the motor blew up.
    Jan 2008
    Nebraska
    from what the guy on nasioc told me, it was ran at stock power levels until ~30k, then swapped for a bigger turbo.
    I'll try to get some pics up later. Its just a light coating of oil residue over everything. Turbine blades, the nut, the housing immediately around the turbine wheel. A light coating, but heavy enough that the blades look wet in appearance compared to the perfectly dry blades of my current stock turbo.
    I doubt its blow by. It would have to be the inverse of blowby. Like blow-suck ha. Blow-by pushes the oil out the crankcase vents, back into the intake tract. It shouldn't touch the hotside though.
    Jul 2008
    San Antonio
    What color is the oil ? Black or redish ? What are the chances it could have been from an over oiled filter combined with blow by.
    If not check the seals.... 30K blown td04 ? Not likely. And he said he ran stock boost ?
    Paul
    2007 MS3
