Personally I think you need to find a new mechanic. There are some very easy ways to find out if you have a head gasket problem.
1) Coolant in oil. Makes the oil turn a tan color.
2) Sweet smell in exhaust/white smoke from exhaust
3)Leak test Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
Also you might just have an air bubble in the system. Try burping the system. Maybe your water pump is taking a crap. Most water pumps have a "weep hole". Jack up the car and see if you got coolant coming out down by the lower radiator hose.
LinkBack URL
About LinkBacks
-Stink-Eye Mob-
I miss my STi
Then I drove it.
I've been addicted ever since.
