CEL after oil change - Page 2
Results 16 to 30 of 31
This is a discussion on CEL after oil change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by 02 wrx haha ya i kinda figured that out. lol but when i get the codes then ...
    May 2005
    Phillytown, PA
    Quote Originally Posted by 02 wrx View Post
    but when i get the codes then what do i do?
    Post them here, so we can help you.
    Jul 2009
    do you think autozone would be a good place to get my codes read?
    Registered User CactusAndy's Avatar
    Aug 2009
    Phoenix, Arizona
    YES! Anywhere that has an OBD II reader can give you the code and then you can post it here so we can try to figure it out for you
  6. #19
    Jul 2009
    alright sweet ill have em in a bit
  7. #20
    but ya i purchased fuel right before the light came on haha
    does that have something to do with it???
    Well...
    Two choices: If you got fuel recently and the CEL appeared after that, remove and put the fuel cap back on and make sure it clicks several times, then wait a while to see what the CEL does. If you didn't get fuel recently get the CEL code and post the number, it will be something like POxxx.
  8. #21
    Jul 2009
    haha ya i checked the fuel thing right away cuz it said in the maual but i just got back from autozone and the code is po546
  9. #22
    Aug 2009
    Phoenix, Arizona
    That code is for your EGT probe (exhaust gas temperature) so you can replace it or do the resistor mod found here on the forums
  10. #23
    Jul 2009
    whats the resistor mod compared to just replacing the bastard?
    haha
  11. #24
    Oct 2005
    Late Devonian
    Wait, isn't the EGT there for a reason and shouldn't one wonder if it is detecting an actual problem?
    Do you have the stock exhaust with cats?
  12. #25
    Jul 2009
    ya for right now all i have on it is a bov and a cold air
    its pretty much stock
  13. #26
    Aug 2009
    Phoenix, Arizona
    Since the car is stock then you do need to replace the sensor, you would only do the resistor mod if you had aftermarket... the code is reading low or high circuit can't remember exactly but mainly its reading too cold which usually means the probe went out
  14. #27
    Jul 2009
    will it screw up my car if i dont replace it until i get my catless turbo back?
  15. #28
    Oct 2005
    Late Devonian
    Quote Originally Posted by CactusAndy View Post
    Yeah, I was just checking that. It does mean too cold, so get a new probe. Unless your cat is failing and is taking out the probe before it chews up your turbo....
    I'd get a catless UP in there and ditch the sensor and disable the code or do resistor mod.
  16. #29
    Aug 2009
    Phoenix, Arizona
    Agreed, just go with a new up and do the resistor mod, good luck
  17. #30
    Jul 2009
    alright thanks fellas much appreciated!
