So you have been jumping your car every time you need to start it for 2 months and wondering what the problem is?
You need a new battery.
This is a discussion on Help me please within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2006 tr i just put in a new clutch. the car now wont start with out jumping ...
I have a 2006 tr i just put in a new clutch. the car now wont start with out jumping from another car with the jumper cables on my car grounded to the block. It turns over very slowly with cables. with out the cables it justs clicks once. when i remove the ground coming off the fenderwell going to the battery it clicks several times. please help me ive been working on this for 2 months.
Thanks
Did the problem start when you replaced the clutch?
Brand new battery and wires also new starter and all new ground wires. Still won't start without a jump.
Yes the problem started after I replaced the clutch, I think maybe a bad ground or a short I'm just having a hard time tracing it.
Check the grounding leads, and check the harness clip on the top of the gearbox.
Thanks for the input i finally fixed it apperently your not suposed to ground the starter.
