Disconnect the test connector under the steering column in the dash. It's not meant to be connected.
This is a discussion on Holy f codes galore need help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; just brought to advanced auto parts today for a diagnostics test today and this is what came up manufacturer control ...
manufacturer control auxiliary emissions controls
catalyst efficiency below threshold
cyl 1 misfire
cyl 2 misfire
cly 3 misfire
cly 4 misfire
exhaust gas temp sensor circuit high (bank 1 sensor Sensor 1)
any easy fixes for this?
bugeye !
pm me if you need custom vinlys.
is that the wire with the green casing on it? if so its not connected.
bugeye !
